Lq4
Originally Posted by 1969x11
Check car-part.com
Originally Posted by GreenBlood
thanks, that website is definitely a plus, if i select Engine as my choice instead of engine block, what parts should I expect to come with it? Would I be better off building off of a block or just buying the complete motor? I am considering a cam in the future, so is there any way i can build a nice cam only 6.0 for under 3g? I most likely will be running long tubes with true duals out the side or dump, but i definitely want a lot of power out of it to get this 5400 pound beast movin...thanks for the help so far...Also, does anyone make an install kit for the 92-99 body style trucks? Do I need any different mounts or parts, or can I just drop it in? Also will it work with the stock trans from the 96? Since I am in college, I want to either build this motor so that my truck feels fresher, or sell it and buy a new truck...Only problem with the new truck is that it would stay stock, and I really want some power...So is cam-only doable, or should I get a stocker and roll the slow life?
i am thinking about buying the engine while I am on spring break from college and then just letting it sit in my garage until I figure out my overall budget and parts...I will probably have my local shop do the install because I am gonna be working full time this summer, and this truck is my DD, so I can't have it down for too long...also,I am probably just gonna get a trans cooler and maybe some other small parts to hold the trans over until it explodes, lol...I don't plan to really beat on the truck once the motor is in, I just like to know that the power is on tap for when I finish it...A converter would eventually be installed as well...
Originally Posted by BlownChevy
are you looking for an entire engine ready to run? I have a long block, complete with water pump and coils that I will make you a HELL of a deal on.
