Lq4
Old Feb 19, 2007 | 11:57 AM
kbracing96's Avatar
Its not by any means an easy drop in replacement for your 5.7, they are 2 completely different engines. I don't know if any one makes adapter motor mounts or, not. Someone may. The computer and everything is different, and you will need some other way to control your transmission. There is a lot to a swap like this, computer, wiring harness, accessory's, mounts, programing, ect. If your on a budget, and time constraint, you would probably be better off just finding a small block 383 long block to just swap in. It would be a direct replacement.
Old Feb 19, 2007 | 01:03 PM
GreenBlood's Avatar
Do you know where I could get that long block and what parts i would need to get it running?
Old Feb 19, 2007 | 01:16 PM
kbracing96's Avatar
A local engine builder would probably be your best bet. You might look for some mail order builders and Summit Racing. A long block is a block, rotating assm, and heads. You would reuse all you intake exhaust and accs, it would just be a rebuilt stroker motor.
Old Feb 19, 2007 | 01:57 PM
mds2004's Avatar
If you go the 383 route and want more than 400hp, make sure you change your intake manifold so you can also up the fuel. With our fuel system, the cap is about 330rwhp.
Old Feb 19, 2007 | 02:54 PM
GreenBlood's Avatar
thanks guys, i'll check out that site...
Old Feb 19, 2007 | 03:30 PM
GreenBlood's Avatar
what about this kit? http://store.summitracing.com/partde...0&autoview=sku
what other parts would I need, and what stock parts could I keep?
Old Feb 19, 2007 | 03:37 PM
GreenBlood's Avatar
http://store.summitracing.com/partde...4&autoview=sku
would this cam work with it?
Old Feb 19, 2007 | 07:05 PM
agreif's Avatar
Check this out. Patrick did what you are talking about in his truck. Didn't hurt that he was in college for electrical engineering. He definitely did teh job right.
http://www.pswired.com/95silverado/p.../6Linstall.htm
Old Feb 20, 2007 | 07:01 AM
GreenBlood's Avatar
thats sweet...but I think I am just gonna go the 383 route...does anyone know anything about the kits i posted?
Old Feb 20, 2007 | 11:54 AM
kbracing96's Avatar
The rotating assm kit looks ok, but I would go with flat top piston (that kit has dished) to keep the compression up since your NA. The cam is pretty mild and would give you good drivability and wouldn't need much tuning I think. Your still going to need some heads though. And you will have to have the block board and prepped for that kit. Your best bet would be to try to find a local builder you could talk to and tell him what your looking for since you seem to have limited knowledge in this stuff. Might save you a lot of money in the long run.
