LPP headers
Old Mar 29, 2010 | 02:46 PM
j_ahlheim's Avatar
Default LPP headers
did you use the gasket that came with the headers or use the gm gasket? I used the gm gasket and I swear I can hear a exhaust leak but its very small only dectectable when driving. I want to know if the gaskets that came with the headers are good or do I need another brand. It was a pain the first time to install I dont want to do it too many more times. The leak sounds like a small puffing sound near the drivers feet under acceleration.
Old Mar 29, 2010 | 02:52 PM
slamdlsx's Avatar
if it sounds like its under the floor board that would be where the header bolts to the y pipe.
Old Mar 29, 2010 | 02:55 PM
j_ahlheim's Avatar
I thought about that and I tightened the S*^% out of those bolts but it didnt change. I used the supplied gasket from lpp on that connection but the stock manifold didnt have a gasket on it. Also remember these are shorty headers not lts so its hard to figure out if its the y pipe or the header to block
Old Mar 29, 2010 | 09:17 PM
andrew383's Avatar
traveling mod
I reused the stock gaskets and have no leaks..
Old Mar 29, 2010 | 09:22 PM
GMCtrk's Avatar
Look at the thickness of that header tubing and compare it to the stock iron manifolds. The stock manifolds are very thick to insulate valvetrain noise. That ticking/puffing noise you're hearing is normal.
Old Mar 30, 2010 | 11:17 AM
j_ahlheim's Avatar
never thought of that. Does everyone one else have this same ticking and puffing from their headers?
Old Mar 30, 2010 | 03:13 PM
03 True Fire's Avatar
yes ive heard the ticking noise before, and it really stood out when i put the cam in, its normal to me.
Old Mar 30, 2010 | 03:15 PM
00ChevyScott's Avatar
Wearin' da big hat
My truck sounds like a sewing machine inside the cab.
Old Mar 30, 2010 | 03:16 PM
Foxxer's Avatar
I used OEM gasket too and applied small amount of thermal silicone to make things tight. Really happy.
Old Mar 30, 2010 | 03:29 PM
supercharged680's Avatar
yeah i have that puffing noise ur talking about... but i assure u i have no leaks at all
