Low oil Pressure
Old Apr 30, 2010 | 11:47 AM
Default Low oil Pressure
Low oil pressure 6.0L t76 front mount
Truck idles at 40 psi when cold, it comes down to 20 psi when it warms up. its a stock 6.0 stock cam. Wont go past 40 psi at WOT
Tried going to heavier oil 15-40 didnt help, changed out the O ring on the pick up tube, It has a new GM oil pump
Checked the pressure manually thru the -4 fitting on the turbo feed line which is coming from the side of the block, and it reads correct
Anything else i have missed? Bad Cam bearing?
Old Apr 30, 2010 | 06:23 PM
Burgundy&TanMan's Avatar
How many miles does it have? If it ha a ton of miles could be the clearances opening up some on the rod/main bearings. Just my .02
Old Apr 30, 2010 | 09:58 PM
fredkj3's Avatar
guy around here had same issues and it ended up being a spun cam bearing... man that sux..
superchomper2003
Aug 26, 2015 09:39 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
Mzay
Jul 6, 2015 11:03 PM
