Lots of KR?? HELP!!
Originally Posted by 02sierraz71_5.3
set pe enrichment rate to 1, its probably not getting enoigh fuel until its too late by then your burried under kr. What do your trims look like?
doesn't this just command a/f ratio of 14.xx? If hptuners even sends me my damn eio interface cable I can log my a/f to see where i'm at. Can't do any tuning without the cable. It's been over 2 weeks. grrrrrrrrr
the pe enrichment rate is for tip in kr, there is a delay on pe enrichment (only on trucks) 1 means give me all the fuel now. Your probably mashing the gas and seeing kr because your not getting enoigh fuel right away. I learned this from jimmyblue and it got rid of my tip in kr. But if your driving down the road at steady tps and get kr that isnt tip in. Once you get hp tuners I would tune the ve in SD that will knock alot of it out if you still have some start looking at the timing tables and nail down the maf.
Just my .02 Im no expert look over in the pcm section it has all the info you could ever want
Originally Posted by JERRY2500
That strange, Everything has been fine since i put the 02 pcm the last week i started getting this KR problem. About 8* KR. I spent a good half day looking for rattles and loose stuff. I know its false knock because i get it at cruising speeds too. I can desensitize the knock sensors but i would like to find out whats causing it before i do that. Keep us posted because i sure want to know how to get rid of it.
My trims are -1.6% on both. Im assuming I read these at idle?? They seem to change depending on the TPS. If I hold steady throttle they are still in the negetive range of -1 to -3.
My problem sounds just like Jerry2500's. Weird??? I have always had KR but it has never shown up under cruise conditions as it does now!!
Thanks 02sierraz71_5.3, setting pe enrichment rate to 1 worked. Cleared all KR at the 5psi setting. Now at 10psi i still have KR but not at tip in. It comes in a little later. I just need to richen it up a little at the top end and that should clear it up. Thanks again
