Lost Or No Power Gain After FAST LSXRT And NW 102TB! (Pics And Vids Inside!)
Old Sep 2, 2013 | 12:56 AM
WhiteX's Avatar
Originally Posted by ScreamingL
a TB is only an opening, a motor is only going to take in as much air as it can use. so size of tb isn't the issue here
The combination of massive tb and massive intake runners in the FAST intake cut down on air intake velocity. Slow moving air will produce less power.
And in all honesty it's much more complicated than that and I truly don't understand/know the theory.
Old Sep 2, 2013 | 02:50 PM
George C....'s Avatar
Formerly ScreamingL
if that's what you believe then so be it, I know of a fast 102/102 combo on a 53 with a mild cam and it doesn't seem to have any lack of
Old Sep 4, 2013 | 03:56 PM
craigsix's Avatar
ive got the fast lsxrt 102mm and a ported and polished stock tb and it makes more power than stock intake and tb did on my 2012 5.3. maybe you need a good tuner. i had area47 do mine.
Old Sep 4, 2013 | 06:48 PM
Blackpanther99's Avatar
IMO. Its a tuning issue.
Old Sep 19, 2013 | 01:17 PM
gnd111's Avatar
On my 404 it made almost 70rwhp over stock 78mm setup with a LSXrt and FAST 92mm.
Bust i lost low end TQ and the HP gain was from 5200 - 6400rpm...
Old Sep 21, 2013 | 07:20 AM
RezinTexas's Avatar
I recently swapped a ported LSXRT and 92TB from the factory Gen 3 truck intake/TB on my 383. I don't have any dyno numbers, however its a massive difference above 4500 rpms. I don't know if I gained as much as gnd111 ^ , but it feels like a completely different engine.
I didn't loose anything down low either. The motor has a smallish cam (224/228) and small runner heads (210), so this might be the reason why I didn't loose any low end.
TA63
Mar 29, 2016 04:38 PM
jdb11386
Dec 3, 2015 09:34 PM
truefire04
Oct 18, 2015 04:38 PM
chacho44
Aug 17, 2015 03:36 AM
DrX
Jul 29, 2015 09:36 PM
