Looking for some traction
Old Sep 1, 2003 | 04:08 PM
Rolling Thunder's Avatar
Default Looking for some traction
I have a set of 18" rims, and 295/75/18, I cant seem to get any traction now that the converter is in. I am getting a set of Nitto 305/45/18 but I think I am going to need a little more than that. I have been thinking about ladder bars but the roads here in VA suck and I dont want bad wheel hop.
Thanks
Old Sep 1, 2003 | 05:19 PM
Hit Man X's Avatar
Default Re: Looking for some traction
Consider some trac bars and a 2" rear drop. I'd just use a set of Lakewoods but apparently Caltrac's work great. Ask Hodgee about them. A rear sway bar may help a bit also.
Old Sep 1, 2003 | 06:27 PM
creederado's Avatar
I think with your na 5.3 you won't have a problem with spinning those nitto's.... there huge. Unless your well over 350 rwhp there is alot of rubber to break loose, 12.50 inches!!! Gmcski has them. Look in the appearance section.
and also check out my yahoo albums-look for my caltrac page.
also here is the linc to a former caltrac post.
https://ls1tech.com/threads/showflat...rue#Post650005
Old Sep 1, 2003 | 09:58 PM
Thanks I was looking at the trac bars and I like them better than the ladder bars anyway. For now the Nittos should be fine. I just finished the trans, now it is on to the rear-end. Just getting things ready for the motor swap. Thanks for the help.
One more question for ya creed, what size Mickeys are those and what is it like lauching with them??
Old Sep 1, 2003 | 10:19 PM
creederado's Avatar
28x11.50-16
You could run a 28x12.50-16 also.
I use tubes and a 8" rim with a 5" backspace. If your running more than a 5" bs(on a 16" rim) you will have brake clearence problems.
I cut 1.9-2.0 60 foot. My lack of hp is about the best It got. They only require a mild burn out.
I not diapointed with them at all.
I'm selling both 20's and MT so I can get nitto's over the winter.
Vortec350ss
Jan 12, 2016 10:36 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
trxmxzx
Sep 23, 2015 09:15 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
MA$TER_E
Sep 9, 2015 03:14 PM
