looking to do a head and cam pack with magnacharger radix...
Old Jul 10, 2003 | 11:19 AM
jonNY's Avatar
Default looking to do a head and cam pack with magnacharger radix...
Im looking to do the following:
CNC-Ported LS1 Cylinder Heads:
Precision CNC-ported chambers and ports ensure maximum flow, velocity, and swirl.
Manley stainless steel 2.020" intake/1.575" exhaust valves feature a high-performance multi-angle valve job.
Milled 63.5cc combustion chambers raise compression ratio to 10.7:1.
Heads are assembled with all new hardware, including:
SLP Titanium Valve-Spring Retainers
SLP High-Performance Valve Springs
GM valve seals and keepers
SLP High-Performance LS1 Camshaft:
Engineered to provide the best possible combination of performance and drivability.
Camshaft Specs: Valve Lift Duration Duration@.050
in: .571" 281º 228º
ex: .571" 281º 228º
Centerline - 112º
Lobe Separation - 112º
Do I need to do a forged piston setup? and if so what should I do?
Then after this is all done, the magnacharger radix.
Do you think this will work. This is a daily driver and its everydayyyyyyy.
Thanx guys.
Old Jul 10, 2003 | 11:21 AM
jonNY's Avatar
Default Re: looking to do a head and cam pack with magnacharger radix...
sorry guys this is a 2003 5.3 z71 chevy avalanche with 4.10
Old Jul 10, 2003 | 12:07 PM
BlownChevy's Avatar
blownerator
25 Year Member
i would not raise the compression at all . With a supercharger set up you want to keep it down. I am planning a head and cam package with my radix wet up and I will be running about 13 lbs of boost daily drivin. The heads and cam will make the boost more efficiant, that way you can run the high boost without problems. Only advice I can give you is do not up your compression ratio.
Old Jul 10, 2003 | 12:57 PM
Pro Stock John's Avatar
Registered User
Yeah you would want to lower compression, which will offset the extra heat generated by the blower which leads to pre-combustion.
If you have a 5.3 motor, I'm guessing the stock compression is lower than 10.1, the pistons are probably in the hole a bit? Unmilled LS1 heads are 67ccs and 5.3's are 62cc so you could drop about half a point in compression that way.
With a safe tune I bet the stock bottom end could go 100K. (just my opinion and not a fact)
Old Jul 10, 2003 | 12:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
Does anyone know the casting number for LS1 heads?
Old Jul 10, 2003 | 01:11 PM
11 Second Club
I would think a dual pattern cam would be better with a SC setup. 9.0:1 compression and crank the boost up. Add an alky kit and run even more boost.
Old Jul 10, 2003 | 01:15 PM
11 Second Club
thereare a coule different casting #'s. Mine are 853, and i think there is a 241 casting. I think the 853 casting is for the vette's (not completely sure about that)
Old Jul 10, 2003 | 01:19 PM
408 Stepside 01's Avatar
casting #'s are
853 (97-00)
241 (01-03)
Old Jul 10, 2003 | 01:29 PM
BlownChevy's Avatar
blownerator
25 Year Member
any reccomendations? is one of them better than the other?
Or would I be better off getting my truck heads done?
Old Jul 10, 2003 | 04:11 PM
Registered User
I would not use your stock 5.3 heads, they have 62cc combustion chambers. You want BIGGER combustion chambers to decrease your compression.
You would need 99-03 LS1 heads to work with your stock 5.3 valve covers.
Or find a set of 6.0 heads which are 70cc's and that's even better.
