Look at these plans and poke holes (09 5.3 'build')
Old Apr 17, 2018 | 01:04 PM
  #21
Choda's Avatar
btr or texas speed cam/dod delete package is the way to go. Itll remove the weak drivetrain and increase torque and hp.
leave the converter alone
obv full exhaust will get you decent amount of power but will be loud.
Old Apr 17, 2018 | 01:26 PM
  #22
b2sdad's Avatar
here is a little clip of my truck at idle for your enjoyment.
Old Apr 17, 2018 | 04:08 PM
  #23
swathdiver's Avatar
5 Year Member
Originally Posted by b2sdad
The truck was tuned, but i'm not sure I really like it??I lost a ton of torque on the low end...That drives me nuts, I need to fix that somehow? Any ideas on how to improve the low end performance?
Did you lose the torque through the tune or the camshaft? A lopey cam like that trades off low end torque for top end horsepower. A good tuner can minimize that but a smaller drop in camshaft is more suitable for a big truck like yours.
Old Apr 17, 2018 | 04:15 PM
  #24
b2sdad's Avatar
that’s the thing, I bought the truck and then immediately had all the work done at my friends shop, so I didn’t have a lot of drive time with it before all the upgrades. You do have a point, Suburbans are heavy, but since the BTR cam is already installed. I’m not taking it out, I have to figure something out to try and get some of the low end torque back.
Old Apr 17, 2018 | 09:15 PM
  #25
swathdiver's Avatar
5 Year Member
I have read an account by a fellow with HP Tuners that was able to fine tune his new camshaft and make it lope or not lope.
Now that the AFM parts are gone, a cam swap is easier and you would not have to pull the heads or the top end off, just the front.
Old Apr 17, 2018 | 09:49 PM
  #26
b2sdad's Avatar
I am hoping for the very same thing. Im sure if we go through the afr numbers and recalibrate for the new CAI Intake and catback, we can smooth things out and restore a little bit of what was lost. As far as the cam lope is concerned, i like it where it is, but if we have to knock it down to restore some bottom end, then so be it.
Old Apr 17, 2018 | 11:28 PM
  #27
swathdiver's Avatar
5 Year Member
A loping camshaft sounds great but does not deliver its power down low, it makes its power high into its rpm band.
Old Apr 17, 2018 | 11:34 PM
  #28
FFDP's Avatar
OP: The TBSS and NNBS intake are the same thing. So doing a TBSS intake wouldn't change anything.
Old Apr 18, 2018 | 12:01 PM
  #29
b2sdad's Avatar
Yeah, according to the website, it starts making power around 3000 rpm.
Old Apr 18, 2018 | 03:39 PM
  #30
swathdiver's Avatar
5 Year Member
I rarely hit 3000 rpms while driving, you've got your work cut out for you.
