long tubes and running rich???
Old Jul 23, 2006 | 03:06 PM
jjpea's Avatar
Default long tubes and running rich???
i put some dynatech long tubes with high flow cats on a couple of months ago, i haven't decided which tuner to buy yet (probably monday, going with HP) the tahoe seems to be running a bit rich using an extreme amount of fuel. i can imagine this is from the exhaust change, how easy will it be for a tuner to help??? thanks
Old Jul 24, 2006 | 11:20 AM
TigerFan187's Avatar
One of the many problems caused by LT's. Everyone has a different experience with LT's. Im a year later since my LT'sremoving cats, and custom tubing and Im still hvaing problems. Get HPTuners!
Old Jul 24, 2006 | 11:33 AM
Should be easy for tuner to fix.
Old Jul 25, 2006 | 01:12 AM
how rich do you think its running? what do you mean by extreme? like 6mpg?
Old Jul 25, 2006 | 11:45 AM
.T.'s Avatar
.T.
Mine did too. Tune helped but my stock injectors are running at 99% so I'm going 8.1 injectors with the head/cam swap.
Old Jul 25, 2006 | 12:35 PM
Moddoo's Avatar
Am I reading this right,
maxed out the stock injectors without boost?
Is your AFR decent?
Old Jul 25, 2006 | 12:52 PM
.T.'s Avatar
.T.
Is your AFR decent?
Trying not to threadjack here but, yes. Here's the most recent dyno sheet.
Old Jul 25, 2006 | 01:20 PM
jjpea's Avatar
i would almost bet that i could make flames come out of my exhaust when she is cold. i'm sure i am still getting around 12-14 on the highway, but driving city, i can almost watch the fuel gauge move. also, i have noticed, even when it warms up, i have almost no bottom end when coming off the line. going into passing gear at around 30 or 35 she screams and throughs you into the seat, not like before. hopefully a tune will get things going the right way, thanks
Old Jul 26, 2006 | 01:02 AM
im hoping my LT's dont mess with my mileage anymore than everything else already has. im gonna need to buy a motorcycle or something. im getting about 15 on the highway. .T., isnt 12:1 close to being a little on the rich side?
Old Jul 26, 2006 | 01:11 AM
02 Tahoe on 20s's Avatar
i did the dynatech LTs, cats and Y as well, and started running extremely rich as well. Cam is going in now, though, so im going for LS1 edit and that will all be gravy pretty soon
Ben
