Which locker?
Old Feb 20, 2005 | 04:34 PM
haulass350's Avatar
Default Which locker?
ok i got 97 silverado and i'm tired of the one wheelie peelie i have now, and am upgrading to a locker, what are the most streetable, affordable, reliable ones? i've been looking at Detroit, Auburn and Eaton, which are the top few i should consider? its a gm 10 bolt 8.5 ring gear, thanx in advance for the help
Old Feb 20, 2005 | 08:14 PM
14 Second Truck Club
Are you looking at the Eaton and Auburn electric lockers or just limited slips? I would say the Eaton Limited slip would be the best choice. A locker might be overkill to have to deal with the noise and such.
Old Feb 20, 2005 | 08:16 PM
KeukaZ71's Avatar
i 2nd that
Old Feb 20, 2005 | 08:30 PM
haulass350's Avatar
deff dont want electric, its a wee bit out of my budget, other then that thou everything else is up in the air, the truck has the factory locker option but it grenaded, and now i cant stand the punch and spin effect i got now, will a limited slip give the same traction perfromance as a locker?
Old Feb 20, 2005 | 08:34 PM
A limited slip will give you two wheel power on take off the majority(almost all) of the time, but still be quiet and driveable in tight situations and cornering. You will have a better unit than the G80 it cam with. Also, the Detroit locker functions different than the factory locker- it is stronger but noisier and less transparent.
Old Feb 20, 2005 | 08:58 PM
I would give a hard look at the detroit truetrac. Looks to be a really good piece and heard guys on here that really like them. If not it I would go with the eaton.
Old Feb 20, 2005 | 09:02 PM
Mr. Sandog's Avatar
I just replaced my G80 with an Eaton Posi unit.
Old Feb 20, 2005 | 09:35 PM
black4x4's Avatar
I'd say go with a detriot if you have one of these your garented to have both tires spinning every time. and it doesn't make all that much noise and it doesn't really hinder your steering. pluss it doesn't have clutch packs that you can toast.
Old Feb 20, 2005 | 09:45 PM
Faze2183's Avatar
what kinda concerns do you have about turnin corners and etc??? im not sure what yall mean about that???
Old Feb 20, 2005 | 10:30 PM
black4x4's Avatar
yeh as long as you cost through a corner you won't even now you have a detriot.
