Which locker?
ok i got 97 silverado and i'm tired of the one wheelie peelie i have now, and am upgrading to a locker, what are the most streetable, affordable, reliable ones? i've been looking at Detroit, Auburn and Eaton, which are the top few i should consider? its a gm 10 bolt 8.5 ring gear, thanx in advance for the help
14 Second Truck Club
Are you looking at the Eaton and Auburn electric lockers or just limited slips? I would say the Eaton Limited slip would be the best choice. A locker might be overkill to have to deal with the noise and such.
i 2nd that
A limited slip will give you two wheel power on take off the majority(almost all) of the time, but still be quiet and driveable in tight situations and cornering. You will have a better unit than the G80 it cam with. Also, the Detroit locker functions different than the factory locker- it is stronger but noisier and less transparent.
I'd say go with a detriot if you have one of these your garented to have both tires spinning every time. and it doesn't make all that much noise and it doesn't really hinder your steering. pluss it doesn't have clutch packs that you can toast.
