LM7 Turbo Guys: Talk to me about 10:1, slight mill, thinner headgaskets
Old 08-23-2015, 11:58 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by lxcoupe
Even after 150k ?
Yes. I have sent a few set of heads in and never had to replace the guides. Even the one's I have sent out to richard at WCCH for CNC porting and that guy is by the book!
Every once in a while a few valves on stock rebuild stuff but usually the guides are still good.
Old 08-24-2015, 02:50 AM
lxcoupe's Avatar
WCCH is obviously the go-to for the c6z guys so if they're good enough for them it's good enough for me. I have to put the btr springs so I'll do a wiggle test on each stem while I'm at it. My whole theme for this build is a. stealth and b. keeping the truck on the road.
Old 08-26-2015, 07:24 PM
bobfig's Avatar
on the lm7 stock gasket is .051" thick. i would go with the thinner gasket first as it helps with better quench over a full mill to get higher compression.
going from a .051" --> .041" nets about a .2 compression with 62cc chambers
general milling the head .0065" = -1cc
you will want to aim to get around 60.5cc to get that 10:1 compression. although the best option would to get some flat top pistons and some 799/243 heads
5.3Okasai
03-09-2022 01:07 PM
Zizzle
10-19-2017 08:44 PM
lawhitediamante
08-12-2015 12:14 PM
lxcoupe
07-30-2015 02:42 PM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: LM7 Turbo Guys: Talk to me about 10:1, slight mill, thinner headgaskets
