LM7 Common Problems
As mentioned above, think valve seals and valve guides first. I had to replace my cam shaft position sensor and my knock sensors plus the knock sensor wire harness. Ditto for a wonky engine coolant temperature sensor. All of this before or shortly after swapping my 150,000 mile 1999 model year LM7 in.
After that, I also picked up random misfires. Tried new spark plugs, new coil packs, new injectors, new plug wires, tried a crank position relearn - all, no help. Finally, I put in a different PCM . . . . haven't had a single misfire in two years or more. This was the absolute last thing that should have been the problem but it was.
Rick
Rick
Rick
Rick
All,
just wanted to update and say truck is running great now. It was the intake manifold gasket. I had to do the job twice tho because I over torque it the first time and leaked even worse. Also popped, clean, and re sealed all injectors. No more oil consumption after cleaning out the PCV orfice and modifying it to act like the newer style valve covers. There is a video on YouTube about it that shows it really well.
thanks for all the help
All,
I've actually been able to remove and reuse intake manifold gaskets. I just inspect them to make sure they are not damaged. I believe the Felpro instructions say to use thread locker on the bolts?
Can you please post a link to the mod you are talking about?
Skidaddalin00
Jun 16, 2021 07:02 PM
renegade4e
Jan 3, 2015 04:08 PM
Preston129
Oct 8, 2010 07:12 PM
