LM7 383 build up
Old Nov 16, 2009 | 10:32 PM
TGriz's Avatar
Default LM7 383 build up
Hello all,
This is a cross post from LS1-tech and LS1Truck
Build Spec:
LM7 5.3 bored and stroked to 383ci
243 LS2 heads
LS6 Cam (405hp version)
using a Walboro 255lph and racetronix 38lb/hr @43.5 PSI & 44lb/hr @ 58 PSI injectors for fuel system upgrades.
Shooting for over 400 on hp & tq
What compression ratio should I be shooting for on this motor? I believe that the stock compression ratio is about 10:1
Going in a 5000lb truck.
I want to run pump gas. preferably 87 octane, but I would go with 92 octane if the benefits were there.
Also would the stock 78mm throttle body be sufficient to supply airflow to this type of motor?
If I was to go with a bigger throttle body which one would you go with and would it need a different intake manifold?
Thanks for all the help guys!
Tyler
Old Jan 4, 2010 | 05:52 PM
TGriz's Avatar
I need a suggestion on a converter for my build.
I ended up deciding on a TR220/220-114 cam.
I have a TB stall available for a decent price. Is this enough stall for this type of cam in this cubic inch of motor? i think its in the 2000-2400 range.
maybe a 3000 stall? or no stall at all?
what do you guys think?
lxcoupe
13
Nov 20, 2015 08:43 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
MA$TER_E
Sep 9, 2015 03:14 PM
screaminian47
Sep 7, 2015 08:20 PM
