LLP's and 4x4 review
Old Apr 4, 2009 | 10:43 PM
  #21
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
id really like to buy a set of these to replace my paceshitters but if the fitment sucks maybe ill just stay with my paceshitters
Old Apr 4, 2009 | 10:44 PM
  #22
GMCtrk's Avatar
lmfao. Paceshitters is a perfect name for them...imo.
If I'm not mistaken you're 2wd....LPP's should be perfect.
Old Apr 5, 2009 | 01:57 AM
  #23
Faze2183's Avatar
Originally Posted by andrew383
have you had your truck flexed out tho?i had mine on 3 wheels a few timeswhich could have caused it,but still ya know...
no...
im a lowered 4x4 :p
Old Apr 5, 2009 | 06:20 PM
  #24
andrew383's Avatar
traveling mod
well im pretty sure thats how my damage happened but it still shouldnt have happened.
for what its worth llp never emailed me back....
Old May 13, 2009 | 11:13 PM
  #25
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Well got my LLPs on today and I have a TON of clearance everywhere, lots of room between the primaries and the front drive shaft and yoke, lots of room between the headers and frame rails everything good, except my steering shaft just barely rubs the header, could have to do with my body lift. Should I take a hammer and give it a little dent to clear or just leave it?
Old May 14, 2009 | 08:16 AM
  #26
truckmann's Avatar
If it rubs even a little I would make some clearance. You probably don't want the direct heat transfer to your steering shaft and it will drive you nuts when it start rattling and jingling on it.
Old May 14, 2009 | 11:21 AM
  #27
budhayes3's Avatar
PT's Slowest Truck
When my old shorties rubbed against my steering shaft, I loosened and repositioned the steering gear box (there's clearance in the bolt holes where it bolts to the frame), and that gave me just enough room to clear the shaft. If you do that, you'll need an alignment though as the angle of the pitman arm will change slightly.
Old May 14, 2009 | 01:21 PM
  #28
Piss Pumps for Sale
Ok this is what Ill doo, how big of a job is this?
Old May 14, 2009 | 04:06 PM
  #29
budhayes3's Avatar
PT's Slowest Truck
It's simple...loosen the 3 bolts that secure the gear box to the frame and shift it as necessary. With mine, I just loosened the bolts and the gear box shifted on it's own and that's all that I needed. Just remember that you'll need a wheel alignment afterwards as the front toe setting is affected.
Old May 14, 2009 | 11:03 PM
  #30
Piss Pumps for Sale
OK sounds good! I need an alignment anyway
AdaMax
May 16, 2016 11:35 PM
nabozny21
Oct 17, 2015 07:47 PM
turbo6c3
Oct 5, 2015 06:11 PM
slimchevy2
Oct 4, 2015 08:02 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
