A little differant 5.3 cam question
Old Jan 20, 2014 | 10:09 PM
kodyowenby10's Avatar
Default A little differant 5.3 cam question
Looking for some cam input for a 5.3 I just bought guy said its a 05 its got 706 heads dish pistons and its going in a 1955 bel air with a 4 speed 3.73 gears 3500ish pounds. I plan to port the heads a little and mainly just cruise the car with a little drag racing now and then.
Old Jan 20, 2014 | 11:17 PM
loganauld's Avatar
Registered User
Texas speed 228r cam with either 112 or 114 lsa depending on what intake you go with
Old Jan 20, 2014 | 11:46 PM
grey matter 04's Avatar
13 Second Truck Club
How much stall you gonna run?
Tsp 220r would be a good cam for your cruise/race style but it will need a stall
Old Jan 21, 2014 | 10:51 AM
joshua022's Avatar
^^ depends on what stall you want to run like grey said, if you don't want to run one, get the comp xr259hr baby cam its real torquey, sounds great, and you don't need a converter.
Old Jan 21, 2014 | 02:04 PM
212/218 is a excellent cam I preferred that over the 220
Old Jan 21, 2014 | 03:00 PM
StrikeZero's Avatar
Originally Posted by kodyowenby10
. . . its going in a 1955 bel air with a 4 speed 3.73 gears 3500ish pounds . . .
If that reads 4speed manual, I don't think he'll need stall
Old Jan 21, 2014 | 03:35 PM
Vortec350ss's Avatar
I think that the 220 is probably a good choice. I assume you want a lot of that classic muscle car sound. If not then the 212/218 would be a good choice. Definitely noticeable at idle, but not as noticeable. What exhaust will you have on there? If you will have stock manifolds then the cam choice will have to change.
Old Jan 21, 2014 | 05:23 PM
4 speed manual with 3/4 length headers ,flowmaster 40's, 44's or someother free flowing muffler and a big lope is fine with me
Old Jan 21, 2014 | 06:03 PM
batboy's Avatar
11 Second Club
You want lope and good power, check out the Tick Performance SNS torqueMAX Stage 1 Camshaft.
Tick Performance SNS torqueMAX Stage 1 Camshaft for LS1 & LS6 Engines - Tick Performance
Old Jan 22, 2014 | 05:19 PM
how bout this?
Part # 54-000-11
Grind # LS1 13045R/13045R HR115+4
Lift .598/.598
Advertised duration 285/285
Duration @ .050 231/231
Lobe seperation 115
ferrellrooster
Mar 6, 2025 03:22 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
grantpo
Jul 15, 2015 12:21 PM
