The Little 4.8 That Could. 488 Rwhp On The Dyno!
Old Dec 27, 2004 | 11:34 AM
Default The Little 4.8 That Could. 488 Rwhp On The Dyno!
HOW FAR CAN THE 4.8 GO? I am pretty sure I found out this past weekend. Tigerfan187 & myself made a trip to the dyno just to see where we were at. I ended up making a couple of difeerent passes with different shots of the gas, here is how the ended up.
the truck makes about 300 rwhp (294) @ 6300 rpms on straight motor with pump gas & 34 degrees of timing
100 wet tnt shot made 390rwhp & 410 ftlbs of torque
100 wet tnt with 70(.42jet) nos dry made 443 rwhp & about the same amount of torque
100 wet tnt with a 120 nos dry made 488 RWHP WITH 22 DEGREES OF TIMING ON STRAIGHT PUMP GAS, NO DETONATION!
Ther is one draw back, I melted 5 of my tr6's the other three were fuel fouled severly. I replaced the spark plugs & everything is fine now but it fu*&ed them up pretty bad.
Has anyone sprayed more! who has the highest 4.8 dyno numbers?
Old Dec 27, 2004 | 11:51 AM
NXRICKY's Avatar
Former Vendor
Why were you running both a dry and a wet?
Ricky
Old Dec 27, 2004 | 12:14 PM
Deckhand's Avatar
Are you running an aftermarket fuelpump?
Old Dec 27, 2004 | 12:19 PM
crazy,when you going to hallsville again. i noticed tigerfan said he was probably going again sometime soon. let me know. i'd like to see yalls xcabs tearing it up. any idea what it will run?
Old Dec 27, 2004 | 12:34 PM
04BlackGmc's Avatar
10 Second Club
Pretty large numbers.
Old Dec 27, 2004 | 12:39 PM
FILE's Avatar
congrats.. those are insane numbers.
Old Dec 27, 2004 | 01:09 PM
Have you taken a look, with a bore scope in the cylinders where the burned plugs were? When i was running a dry shot on a 4.8 i burned 3,5&7 plugs. I put in a set of new plugs in it and it ran fine. just for the heck of it i pulled them back out and found that i had burned the top of #5 & 7 pistons. #5 had light speckling and #7 had burned the outter part of the piston to the top ring.
Old Dec 27, 2004 | 01:26 PM
moregrip's Avatar
what a rush!
congrats crazy!
Old Dec 27, 2004 | 01:29 PM
Ricky
why not? I originally pieced together the dry system, came across a deal on the wet, so i decided to two stage it, the dry shot is a hole shot wich is a 70 hp, then I hit the wet. It dropped me to 12.75 from 13.31
Old Dec 27, 2004 | 01:30 PM
no, just the factory
