Lingenfelter GT2-3 Cam Card
Old Mar 21, 2005 | 11:55 PM
moregrip's Avatar
what a rush!
Default Lingenfelter GT2-3 Cam Card
Can someone post the Cam Card Specs on this? thanks
looking for
Intake Opens BTDC
Intake Closes ABDC
Exhaust Opens BBDC
Exhaust Closes ATDC
Old Mar 22, 2005 | 12:48 AM
Mr. Sandog's Avatar
Did you try Lingenfelter?
Old Mar 22, 2005 | 12:52 AM
moregrip's Avatar
what a rush!
yes and no. not recently
Old Mar 22, 2005 | 08:15 AM
02sierraz71_5.3's Avatar
ive got the gt2-5 if those numbers will help
Old Mar 22, 2005 | 09:05 AM
moregrip's Avatar
what a rush!
sure, post em up.
if someone has the gt7 i'll take those too
Old Mar 22, 2005 | 05:18 PM
LPE GT2-5
duration at .050 222/222
lobe lift .333/.333
112lsa
gross lift .566/.566
duration at .006 tappet lift 275/275
open close
valve timing at .006 int:25 exh: 69
BTDC: 69 BBOC: 25
The lope on this cam is unmistakable, sounds like a harley in my 5.3 moved power curve out around 800 rpm . Drivability is so so requires alot of tuning still have alot of hot start issues cranks over easily when its cold though all I have to do is touch the starter.
Old Mar 22, 2005 | 05:22 PM
all LPE's grinds are made by comp and use comp lobes either xr or xer
for 250 I think theyre a good deal
similar comp cams cost 400-450
Old Mar 22, 2005 | 07:16 PM
Mr. Sandog's Avatar
You can get any custom grind from Comp for $395....or less if you're nice.
bighouse
Aug 14, 2015 08:00 AM
lawhitediamante
Aug 12, 2015 12:14 PM
CashDudeHomie
Aug 3, 2015 10:58 AM
Atomic
Jul 11, 2015 03:51 PM
banker099
Jul 4, 2015 05:50 PM
