likelyhood of 12's NA?
Old Mar 7, 2008 | 12:00 AM
06sierra5.3's Avatar
Default likelyhood of 12's NA?
i'd love to do a 408 but its not in the budget right now. i can pick up a decent lq9 for about $1500. i want to go all out on the top end; heads, cam, ls6 manifold, TB, etc. i have an extended cab. the plans i had for my 5.3 wouldve put me close, but i dont think anyone has hit 12's NA in extended cab. plus i want to do 100 shot in the 6.0. thoughts?
also, what cams and heads would be recommended, i know there are several out there, but can someone point me in the right direction? i have a yank 3000 stall that i dont really want to replace, but wouldnt be the end of the world if i had to, to get what i want. looking to build a NA monster with stock bottom end.
Old Mar 7, 2008 | 08:53 AM
ZZebes's Avatar
there are a few 12's N/A in an Extended cab in fact plenty of them
me
AP2002
TXSilverado
and the list goes on, a stock LQ9 with a cam will crack a 12 N/A
Old Mar 7, 2008 | 09:26 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
David, did you make 12's? My brain is scattered lately, congrats.
It does take a bit of work to get a 5000lb truck into the 12's. Good luck on your quest!
Old Mar 7, 2008 | 09:28 AM
joshua022's Avatar
adrenalinep is the only ECSB to do 12s in a 5.3 N/A so far, hopefully until sunday when I go to the track.
Old Mar 7, 2008 | 09:32 AM
99Silverado5.3's Avatar
Full bolt on 6L with cam, gears, & converter should get you there.
Old Mar 7, 2008 | 09:59 AM
i have stock g80 with 3.73. eventually will go with true-trac.
this setup will take some time to come up with the funds, but i will be buying the dynatech setup with cats.
full bolt on lq9 with long tubes, how to you think my transmission will fare with the mods ive done to it?. i will keep 20% torque management.
eventually will do 100 shot, but will beef up the rearend and buy new flt trans first.
Old Mar 7, 2008 | 10:08 AM
I would definately skip the dynatechs and go pacesetters unless you find a better deal on them than the pacesetters. Any reason for cats? Just take them off and tune them out. If you want to keep it quiet put a BIG magnaflow on it. I'm on a stock trans besides converter with 25% tq management still in & almost 95k on it with a 6L, almost full bolt-on, & cam.
Old Mar 7, 2008 | 10:09 AM
joshua022's Avatar
leaving 20% TM in isn't going to really help prevent trans failure by a significant amount.
if it happens it happens...I have a full-bolt on 5.3 with heads/cam/stall and just passed 103k on my stock tranny with every little bit of TM removed.
Old Mar 7, 2008 | 11:00 AM
20% is for peace of mind
im in CA, they have roadside smog checks and inspections. i have to have cats for visual inspections
hirdlej
Dec 16, 2009 11:55 AM
hirdlej
37
Nov 7, 2008 07:30 PM
