CAM help
Old Mar 2, 2008 | 11:19 PM
dusty4.8's Avatar
Default CAM help
ive got an 04 silverado with the 4.8l and a 5speed im wanting to install a cam i have a friend that wanted to put a 6.0l cam out of a gto in this weekend but i want something thats going to perform and hit a lick if you know what i mean i want it to be heard and make a noticable difference in the performance,and the 6.0 cam just wont do. does anyone have any ideas for a good cam choice,im also going with a set of LT pacesetters and off road y-pipe for better exhaust flow and will probably set up for a dyno tune or custom tune from my buddy
Old Mar 3, 2008 | 03:28 PM
sv650lex's Avatar
I don't think it's a easy swap. I believe the 6.0 cam is a ls2 cam so you need some other parts. Do an LS2 search and you will get more info on what is needed.
Old Mar 3, 2008 | 03:38 PM
joshua022's Avatar
I wouldn't waste your time on that cam, it won't be much a difference and it won't "hit a lick" look around in the internal engines section an do some more research. you'll be happier in the long run with whatever cam you do decide to use.
Old Mar 3, 2008 | 07:10 PM
dusty4.8's Avatar
thanks yeah i know ill have to chance lifters and valve springs with the cam swap, what cam are you runing joshua022
Old Mar 3, 2008 | 10:36 PM
Yellowsierra's Avatar
I would go with a VRX-4! 228/230.http://www.vengeancerd.com/cart/products.php?cat=115
Here's a vid of a 228/232 in a 4.8. http://video.google.com/videoplay?do...58366744349086
Lator man,
Gator
Old Mar 3, 2008 | 10:50 PM
1989k1500's Avatar
You have a stick so that means you are obligated to get a big *** cam. IMO
Old Mar 3, 2008 | 10:52 PM
I love big cams!
Old Mar 3, 2008 | 10:57 PM
dusty4.8's Avatar
i love big cams too whats wrong with big cams ecspecially when you have a stick
Old Mar 3, 2008 | 11:00 PM
RandomHero's Avatar
Lator man,
Gator
Those are both WAAAY too big for a 4.8L. I have a 224/224 on 112 lsa in my 5.3L and even in my bigger engine it's not the best for daily driving. I would go no bigger than a 220/220
Old Mar 3, 2008 | 11:06 PM
I know you may lose some low end torque with a big cam but I think he's wanting more than power...I think he's wanting it for the sound! Oh and a 228/230 is going to sound wicked compared to a little 220/220.
