Which lifters?
Old Apr 8, 2007 | 07:04 AM
SSSBLKOUT's Avatar
Default Which lifters?
The engine is a stock 346 shortblock and WCCH stage 2 5.3s. It is going to be a very mild setup. Not looking for a "max effort" engine, just something with a little more than normal, and an FLT 4L60e behind it. Probably going to put Efans and definately a full exhaust, too.
The cam will be a short duration (208/210 .560/580, somethnig in that range, because I want a very low power band, and high torque) if I go with GM lifters. My question is if I use the Rhoads lifters, will I be able to use a cam with a little bit more duration (214/216, with the same lift, approx.) and not sacrifice the bottom end torque?
Also, are those lifters any more a pain in the *** (higher fail rate, require more maintenance), becuase of how they operate?
Old Apr 8, 2007 | 07:06 AM
Flyer's Avatar
For what you are saying there ... I'd stick with stock ones.
Old Apr 8, 2007 | 07:23 AM
budhayes3's Avatar
PT's Slowest Truck
Here's a link to some lifters on SDPC's website: http://www.sdparts.com/product/12499...esSetof16.aspx
Old Apr 8, 2007 | 07:24 AM
SSSBLKOUT's Avatar
I know that the stockers will be just fine, but will I be able to get 5 or 10 more HP on the top, without sacrificing the bottom?
Old Apr 8, 2007 | 07:38 AM
SSSBLKOUT's Avatar
Here is a Tech page that I found, some good info. One thng is for sure, I ain't using them, I don't watn valvetrain noise on my DD.
https://ls1tech.com/forums/showthrea...rhoads+lifters
Old Apr 8, 2007 | 03:28 PM
nightrunner's Avatar
Mr. Obvious
ive heard of lots of problems from the COMP-R lifters
if you want to upgrade id say get some ls7 lifters
Old Apr 8, 2007 | 04:20 PM
405hpta's Avatar
Banned
Comp "850" Lifters, they are a stock style replacement, none of the hassles that the "R" lifters have had. If you are intersted let me know, I have a set for sale.
Old Apr 8, 2007 | 07:05 PM
99Silver6.0's Avatar
Comp R's bad. Stock style Comps are ok. Melling makes some too, JB-2079. Theres also the Morels!!!!!!!!! But you wont like the price tag.
Old Apr 8, 2007 | 07:08 PM
Quik's Avatar
5 year bitches!
theres only one lifter for your needs and most of everyone's needs and they are the
LS7
ive ran them in my old motor and now in the 408
my old motor which now has a larger motor now has around 11k on those lifters and see 7k daily
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
zblee
Sep 19, 2015 06:33 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
