lifter tick?
Old Sep 9, 2013 | 05:55 PM
Boosted_Silverado's Avatar
Default lifter tick?
needs some input on what you guys think this noise is, sounds like a ticking lifter coming from cylinder 5 or 7.
Old Sep 9, 2013 | 06:29 PM
cammed00's Avatar
Ruh roh
Old Sep 9, 2013 | 07:56 PM
supercharged680's Avatar
sounds like a lifter tick to me
Old Sep 9, 2013 | 08:05 PM
BigDaddy0381's Avatar
time for some BTR SLR lifters. There nice!!!
Old Sep 9, 2013 | 08:39 PM
black00chev's Avatar
Slowest turbo build ever!
What lifters did you put in?
Old Sep 9, 2013 | 10:39 PM
I used ls7 lifters.
Old Sep 9, 2013 | 10:57 PM
Bit's Avatar
Bit
I've seen LS7 lifters flat spot on the roller and cause problems. I've only seen it with big cams and a lot of spring pressure.
Old Sep 9, 2013 | 11:22 PM
Foxxer's Avatar
Can't go wrong with LS7's.
Old Sep 10, 2013 | 02:34 AM
oakley6575's Avatar
I agree. LS7's are a good lifter. Did you pull the valve cover off and check the rockers yet?
Old Sep 11, 2013 | 08:27 PM
i didnt have time to check anything over yet.
im going to pull the valve cover off tonight and check the rockers.
if they look fine i guess ill be pulling the heads off and replacing the lifters
