lifter tick?
Old Sep 12, 2013 | 12:57 AM
jmgak47's Avatar
It may sound like a ghetto way of fixing it but it worked well on my Ram and many others after engine work.
High-Performance Oil Treatment (p/n 4471) | Products | Bar's Leaks & Rislone - Premium Automotive Chemicals
After the next oil change the tick should be gone using any oil you like.
Old Sep 15, 2013 | 12:53 PM
James B.'s Avatar
Are you sure it's lifters and not a plug that's loose or cross threaded? Lifters have a discreet and short tick to them when making up lash, this sounds like a noise of longer duration.
Old Sep 15, 2013 | 06:39 PM
batboy's Avatar
11 Second Club
Do you have the right length of pushrod? Meaning, did you do the proper measuring?
Old Sep 16, 2013 | 07:31 AM
whippled 8.1l build's Avatar
was this a cam swap or did it just come up out of no where..
Old Sep 16, 2013 | 01:14 PM
Boosted_Silverado's Avatar
yes i did, they are ls7 lifters with 0.075 preload
its a new engine with maybe 1/2hr run time on it.
Old Sep 16, 2013 | 01:19 PM
agressive cam?? is so it can be normal noise.. i have a ton of noise from mine and it is completly normal..
Old Sep 16, 2013 | 08:36 PM
finally had time to work on it today.... looks like a lifter has collapsed.
Old Sep 16, 2013 | 09:11 PM
hsiriyob's Avatar
what do you think caused the problem? Im having issues with my 346 d1sc. i was driving it yesterday and heard knock or a lifter tick. I just put the heads and d1 on the truck. good luck man i feel your pain.
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
Brandonlflr12
Sep 8, 2015 09:01 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
