lifter noise?
Old Feb 19, 2012 | 10:42 PM
greasemykey's Avatar
Default lifter noise?
i have been tearing into my 5.3L looking for my "knock". i have found that all rod bearings and mains are good. valves are in place and springs are not broke. could i have a failed lifter causing a hard knocking sound and a engine misfire? how can i tell if my lifters are good?
Old Feb 20, 2012 | 04:18 PM
2006bowtie's Avatar
basically just pull them. i had one lifter completely destroy itself and on the roller on the bottom broke in half, basically causing it to look like a flat bottom, losing some lift, both causing a missfire. in both cases i could move the rocker arm a little, it was almost as if it wasnt torqued down but it really was. it actually chewed up my cam lobe too, so the cam had to be replaced. id pull the heads look at the lifters and check the cam. took me about 2-3 days workin 8-4 on my 06, also no expierence doing it before. it almost ruined my lifter passage, i had to hone it out a little to make it smooth again. catch it before it ruins something else, i learned that the hard way. lol
Old Feb 23, 2012 | 11:15 PM
it wasnt the lifters. somehow i destroyed the tops of 3 pistons and the heads. something ended up in the combustion chambers.
Old Feb 23, 2012 | 11:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Carnage pics please.
Old Feb 23, 2012 | 11:36 PM
how do i put pics up here? i have them on my phone.
Old Feb 23, 2012 | 11:38 PM
Photobucket. Use the [img] code.
Old Feb 23, 2012 | 11:41 PM
Old Feb 23, 2012 | 11:42 PM
ill take better pics tomorrow as i was using my cell phone at night. but that is cylinder 5 and 7. I pulled the other head off and 8 is chewed up to. but the cylinder walls are good so im not sure what the hell happened. notice the smashed spark plug?
Old Feb 23, 2012 | 11:46 PM
I'll have to get a better look at them tomorrow, I'm on my phone right now, hard to see details. But yeah, looks like you got problems. Time for a rebuild and make it mo' betta!!
JordanH
Nov 6, 2015 07:42 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
