Lifted 98 K1500 5.7 3" xpipe question
My truck has shorty headers with a pieced together ypipe right now and I am going to be changing it.
I already have a set of long tube Pacesetter headers, a universal x pipe kit and 2 3" Warlock mufflers. I have not removed the old exhaust, but at first glance I dont think I can use the xpipe with the crossover centered. I am thinking of using a configuration similar to the image attached, any one have experience with this setup?
It would be better if you could run a h-pipe from 1 bank to the other just after the longtubes if thats possible.
You would see better gains form simply getting rid of the stock 1/2 ton 1 7/8" headpipes and going with aftermarket headpipes, or going with 3/4 ton headpipes.
The larger pipes and cats are the stock 3/4 ton Vortec 350 pipes, smaller are stock 1/2 ton Vortec 350 pipes.
Notice the stagger of teh stock cats, they are trying to keep the amount of pipe the same. Doing so helps with the tuning effects of the exhaust. This is esp. important if your headpipes are the same diameter as the header collector. If the pipe and collector diameter is teh same, the collector length is effectively terminated at the point where an obstruction or change in diameter is encountered. if pipes diameters are thesame, the effective collector length would be from the header collector until the cats. Collector length is part of tuning the exhaust.
I did LT's suing dual 2 1/2" pipes into dual 2 1/2" cats into a dual in/out muffler, then into dual 4" pipes out the side before the passenger side tire. That with a simple a/f ratio change only tune had major gains in off idle launching and all rpm power as compared to the stock
manifold/headpipe/cat and tune.
Just my opinion.
peace
Hog
GXPJAY
Nov 5, 2015 06:49 AM
grantpo
Jul 15, 2015 12:21 PM
GreyChevy
Jul 7, 2015 08:57 PM
