Lets Talk Rockers?!
Old Mar 2, 2006 | 09:50 PM
1TRUESS's Avatar
Default Lets Talk Rockers?!
All this talk about the LS7 rockers made me wonder if I could find a cheep set of rockers instead of getting a cam. It would be an easier install!
So if I have a stock cam 5.3L I would have:
Stock ? lets say
1.7 = 204/218 555/551 LSA117 I know ths is not stock specs
1.8 = 216/231 588/584 LSA117
1.85= 222/238 604/600 LSA117
Is this right?
Would I need a new tune and would it be worth it? I just want to know if I am understanding this right.
Also what is the stock specs on a 2002 LM7 Cam?
Old Mar 2, 2006 | 10:00 PM
Yelo's Avatar
No...with higher ratio rockers only the lift changes on the cam, the duration...for all intents and purposes worth speaking of....doesn't change at all (it DOES change...but not enough to measure without a micrometer)
Old Mar 2, 2006 | 10:06 PM
TurboGibbs's Avatar
I agree with yelo. From my previous research and common knowledge it won't increase your duration much at all. I have heard claims of 2-3* but i'm sceptical of that.
Old Mar 2, 2006 | 10:08 PM
FarmerBeau's Avatar
Sexy Party Mod
Yea Yea, this would be good info to know. I know how to determine the lift on different ratios but Im not sure how to determine the change in duration. If anybody knows the formula or anything, lemme know. I dont mean to hijack your post. sorry.
But if i were you, i would get a tune. I think the change in lift and duration would cause a few problems on the stock tune. Dont quote me on it though.
Old Mar 2, 2006 | 10:23 PM
Yelo's Avatar
A change in lift is going to affect VE only.....and (within reason) the LTFT's can make that up. A tune is ALWAYS a good idea though......
Old Mar 3, 2006 | 06:08 AM
tdrumm's Avatar
Since the LS7 rocker didn't pan out, the cheapest 1.8 rocker I've seen are Harland Sharp non-adjustables, and they cost as much as a cam does. Don't forget that even with just 1.8 rockers you will need new valve springs as the stockers are barely up to task for the stock cam. Right there you are almost at the cost of a cam swap.
Yes, the install is more involved, but C'mon, you were the first to replace a 4L60E with a T-56, you can't be scared of a cam swap!
Old Mar 3, 2006 | 04:02 PM
99Silver6.0's Avatar
Jesel shafts or Yella Terras are the only rockers worth the cash or trouble. Adjustable rockers are a pain in the nads!! Just toss in a cam man. Yoll be alot happier with the end result!!
Old Mar 3, 2006 | 05:14 PM
1TRUESS's Avatar
I was just wondering!? Thanks for the info guys!
Good point! I was actually the third. I was the first to come out and post about it!
Old Mar 4, 2006 | 07:51 AM
SweetS10V8's Avatar
I disagree, epsecially since were not even talking about a soild cam that might need adjustment twice a year. This is a "Set it and forget it" hyd cam. And if your scared of adjusting lifters, you need to find a different hobby
As far as the 1.8:1 rockers go, I dont understand why people a lot of the time think they need them. Id stay with as close to a stock ratio as I could. DO you have actual flow numbers from your head showing that there is flow potential at the higher lift?
If you want more lift, buy a bigger cam is my theory. But Im all wierd like that I guess
Old Mar 4, 2006 | 12:01 PM
Not scared of adjusting lifters at all. Always seems somebody on here is having problems with adj rockers on these engines. Along with LS1 guys, they are a pain in the ***. 2 each their own. Im using non-adj shaft mount Jesels. They arent even a necessity like you say. Stock rockers are sufficient. But these were given to me, so im using them.
