Lets talk flex plates ?? Quicky
Old Dec 19, 2007 | 09:26 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Lets talk flex plates ?? Quicky
Ok I have done a search on this and have came up with a lil of both on this. I have a 6.0(05) and will be putting it in my truck this fri. I have the 4.8(03). Now I have read that you need to use the 4.8 FP on the 6.0 and have also read others have not changed them and that they are the same. So what is it????
Than you
John
Old Dec 19, 2007 | 09:28 PM
nonnieselman's Avatar
if the 6.0 had a 80e behind it then the FP has a spacer behind it... cant use that one... just take the one off your 4.8 and bolt it up...
Old Dec 19, 2007 | 09:40 PM
Baltimore Whore
Ok it would have since it came out of a 2500. Also so if it would have came out of a denali or esky, it would be fine, as they use the 65e, correct me if i am wrong. Is the spacer built onto the flywheel, or is it just a completly different wheel all togather.. Again thanks
John
Old Dec 24, 2007 | 10:01 PM
MGMC's Avatar
12 Second Club
the spacer is seperate from the flywheel. you take the 6.0 flywheel off and there is a round thing that the FW bolts on to. just barely thread 2 bolts on it and turn it. it will come right off. then bolt up you 4.8 FW and your golden
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Wolftrk99
Oct 2, 2015 08:17 AM
trxmxzx
Sep 29, 2015 07:42 AM
Slammed silverado
Sep 28, 2015 06:14 PM
