Lean Cylinder?
Old May 1, 2008 | 07:50 PM
SRT10KLLR's Avatar
Former Vendor
Default Lean Cylinder?
I have read that the #7 cylinder runs leaner than the rest. Is this correct? Which cylinders run the leanest? I am switching to bigger injectors that came with a flow sheet so if I know the cylinders that run the leanest then I can install the ones that flow more in those cylinders.
I will be running 15+ lbs of boost so it might be more important than if I was running N/A. The injectors I am using are in this thread: https://www.performancetrucks.net/fo...=416134&page=2
Old May 2, 2008 | 02:48 PM
SRT10KLLR's Avatar
Former Vendor
Assuming that the injectors are in the following order:
8 - 7
6 - 5
4 - 3
2 - 1
I had the injectors that flowed the most put in the back and weened them out until it reached the front. I am not sure if the intake was causing the #7 cylinder to go lean or if the cooling causes that cylinder to fail more often. I figured that if the back cylinders were a little leaner than the extra fuel would help and if it was because they were running hotter than the extra fuel would help cool them.
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
