Larger oil filter
Old May 16, 2009 | 04:45 PM
Breeze's Avatar
11 Second Truck Club
Thanks for the info I miss the old Pf-59.
Old May 17, 2009 | 02:55 PM
03lowriderss's Avatar
great info guys. thank you very much!!
Old May 17, 2009 | 09:49 PM
brandoz28's Avatar
PF61 is the number for a longer filter, just screwed one on my truck friday.
Old May 18, 2009 | 07:16 AM
Tootall's Avatar
when you go to get a filter, and they ask what engine size you have, just say that it's for a 6.0. They'll give you the "longer" filter.
4.3, 4.8, 5.3 all call for the short filter size
so same year . . . just say that you have a 6.0
Old May 18, 2009 | 10:40 AM
krambo's Avatar
Originally Posted by Mort
Amsoil has a filter that is longer than the one they spec EaO32.
I use an EaO64 which crosses over to the PH 59 I think. It is definitely longer than the EaO32 and much easier to get a filter wrench on. It has the anti-drain back valve as well.
Yep.
Amsoil Ea064
K&N HP-2006
Those are the two "long" filters that I use exclusively. Both are high quality filters...pricy however you get what you pay for.
Old May 18, 2009 | 11:26 AM
Noah Burns's Avatar
Originally Posted by krambo
Yep.
Amsoil Ea064
K&N HP-2006
not really... these aren't high precision Nextel Cup engines we're dealing with here... and even those engines don't run "pricy" filters... lots will have either a fram or wix on them... just sayin...
Old May 18, 2009 | 11:29 AM
00ChevyScott's Avatar
Wearin' da big hat
you wont find them running a 3.99 fram extra guard filter though. They run the higher end line of fram which is similar to the K&N and AMSoil filter
Old May 18, 2009 | 03:19 PM
Noah Burns's Avatar
they run the one with the lowest restriction to protection ratio, whichever one that is, rather it costs $.01 or $100
Old May 18, 2009 | 03:22 PM
Noah Burns's Avatar
I put over 100k of the hardest miles imaginable on the original motor in my previous truck, nitrous, over revs, big cams, 6500rpm shifts, banging the revlimiter, running 130+ down the highway for miles at a time... all the time using mobil 1 15/50 and the absolute cheapest oil filter I could find (pennziol filter from kwik kar) and that motor looked like something God himself had built when it came apart. if you take care of the stuff, change it when it needs to be changed, and maintain it properly, you'll be just fine... don't get caught up in "this is better than that" it usually isn't.
Old May 18, 2009 | 09:11 PM
S/C Z71's Avatar
Banned
Mobil 1 filter is good but the K&N is garbage.
