Larger oil filter
when you go to get a filter, and they ask what engine size you have, just say that it's for a 6.0. They'll give you the "longer" filter.
4.3, 4.8, 5.3 all call for the short filter size
so same year . . . just say that you have a 6.0
Yep.
Amsoil Ea064
K&N HP-2006
Those are the two "long" filters that I use exclusively. Both are high quality filters...pricy however you get what you pay for.
not really... these aren't high precision Nextel Cup engines we're dealing with here... and even those engines don't run "pricy" filters... lots will have either a fram or wix on them... just sayin...
I put over 100k of the hardest miles imaginable on the original motor in my previous truck, nitrous, over revs, big cams, 6500rpm shifts, banging the revlimiter, running 130+ down the highway for miles at a time... all the time using mobil 1 15/50 and the absolute cheapest oil filter I could find (pennziol filter from kwik kar) and that motor looked like something God himself had built when it came apart. if you take care of the stuff, change it when it needs to be changed, and maintain it properly, you'll be just fine... don't get caught up in "this is better than that" it usually isn't.
