Large dish pistons w/small chamber head vs small dish pistons w/ large chamber head
High on diesel fumes
Originally Posted by Keith
Progress?
FWIW - Richard, David, and Rex are great guys and have been extremely helpful. I should have worked with them the first time around.
Glad to hear it is getting taken care of. I see that Jones cam is going away. Plans for a new one?
As of right now, the tentative plan is to reuse my Callies Dragonslayer crank and Compstar rods, go with a smaller dish piston (Wiseco was recommended) and larger chamber heads (the 317's apparently are more efficient at removing exhaust heat, which should cut down on knock), and some plasma-moly rings. Camshaft is still up in the air. I may stick with the Z06 cam, or possibly something a little larger. I need to talk to Richard more about his recommendations there. Based on Rex's recommendations, the target SCR is 9.0-9.25:1, and I'll be swapping back from the .040" Cometic gaskets to some stock .054" gaskets.
Sounds like everything will be taken care of. Did you ever discuss your issues with the guys that originally built it? I mean wasn't there some kind of warranty. Are they denying it saying it was the heads, because didn't you eliminate that variable by switching heads?
Ahh, cool. Thinking about something like a straight pattern cam, or a reverse slit for the turbo? 2-3mpg is a pretty impressive gain from a cam swap, although that other one was huge.
Although smaller in displacement than you, check out Harlan's setup:
https://ls1tech.com/forums/showthread.php?t=306077
GrooveCityZ71
Aug 31, 2015 12:05 PM
lycominghunter
Aug 15, 2015 12:26 PM
