L96 or Bust!!
Old Aug 11, 2010 | 10:34 PM
LS1MonteSS's Avatar
Default L96 or Bust!!
Hello & thanks for looking at this..
Ok my situation is that I have a good line on a L96 w/ 6L90E, complete..
But because it is a new motor for 2010 there isn't alot of info out there on the motors... I know the 6L90E is a good find as it is stronger than the 80E, But the 90E is a little larger and a tad bit heavier...
As for the L96.. What is out there in the way of upgrades to help boost the HP up from the 352 that is reported..
Any help would be nice.. Like I mentioned all my LS books have no information past 2009 so I'm stuck!!
Old Aug 12, 2010 | 09:05 AM
NightmareTBSS's Avatar
Im not sure about the L96 as its the new HD engine. But im sure as far as hp gains and power adders, a good tune and bolt ons would get the 352 up more.
Here are the stats on it:
2010 Vortec 6.0L V-8 VVT ( L96 ) 6/5/2009
Description: 6.0L Gen IV V-8 Small Block
Type: V-8
Displacement: 5967cc (364 ci)
Engine Orientation Longitudinal
Compression ratio: 9.6:1
Valve configuration: Overhead valves
Valves per cylinder 2
Assembly site: Romulus, MI
St. Catharines, On
Silao, MX
Valve lifters: Hydraulic roller
Firing order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke: 101.6 x 92 mm
Bore Center (mm) 111.76
Fuel system: Sequential fuel injection
Fuel type: Applications:
Regular unleaded Chevrolet Silverado HD, Chevrolet Suburban, GMC Sierra HD, GMC Yukon XL
Regular unleaded Chevrolet Express ( Cutaway ), GMC Savana ( Cutaway )
E85 Flex Fuel Chevrolet Express ( Passenger,Cargo ), GMC Savana ( Passenger,Cargo )
Engine Mass TBD
Applications: Horsepower: hp ( kW )
Chevrolet Silverado HD < 10,000 lbs 360 hp ( 268 kW ) @ 5400 rpm SAE CERTIFIED
GMC Sierra HD < 10,000 lbs 360 hp ( 268 kW ) @ 5400 rpm SAE CERTIFIED
Chevrolet Silverado HD > 10,000 lbs 322 hp ( 240 kW ) @ 4400 rpm SAE CERTIFIED
GMC Sierra HD > 10,000 lbs 322 hp ( 240 kW ) @ 4400 rpm SAE CERTIFIED
Chevrolet Suburban HD 352 hp ( 262 kW ) @ 5400 rpm SAE CERTIFIED
GMC Yukon XL 352 hp ( 262 kW ) @ 5400 rpm SAE CERTIFIED
Chevrolet Express 323 hp ( 241 kW ) @ 4600 rpm SAE CERTIFIED
GMC Savana 323 hp ( 241 kW ) @ 4600 rpm SAE CERTIFIED
Applications: Torque: lb-ft ( Nm )
Chevrolet Silverado HD < 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
GMC Sierra HD < 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
Chevrolet Silverado HD > 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
GMC Sierra HD > 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
Chevrolet Suburban HD 382 lb-ft ( 518 Nm ) @ 4200 rpm SAE CERTIFIED
GMC Yukon XL 382 lb-ft ( 518 Nm ) @ 4200 rpm SAE CERTIFIED
Chevrolet Express 373 lb-ft ( 506 Nm ) @ 4400 rpm SAE CERTIFIED
GMC Savana 373 lb-ft ( 506 Nm ) @ 4400 rpm SAE CERTIFIED
Maximum Engine Speed: Silverado, Sierra, Suburban, Yukon XL = 6000 rpm Express, Savana = 5600 rpm
Emissions controls: Catalytic converter
Three-way catalyst
Positive crankcase ventilation
MATERIALS
Block: Cast iron
Cylinder head: Cast aluminum
Intake manifold: Composite
Exhaust manifold: Cast nodular iron
Main bearing caps: Powder metal
Crankshaft: Cast nodular iron with undercut and rolled fillets
Camshaft: Hollow steel
Connecting rods: Powder metal
Additional features: Electronic throttle control
E85 Flex Fuel
Extended life accessory drive belt
Extended life coolant
Extended life spark plugs
Oil Life Monitor System
Variable valve timing ( VVT )
and it uses the same style heads found on the 6.2 which are the rectange heads (L92 heads)
Old Aug 12, 2010 | 09:16 AM
silver-mod-o's Avatar
Hunt&Fisherator
LS3 and L92 heads are not the same but they are both of the GEN IV variety. What's the casting number on them?
Old Aug 12, 2010 | 09:28 AM
Typo..got carried away
fixed
Old Aug 12, 2010 | 06:04 PM
schino's Avatar
sounds like the newer version of the ly6/6l90 combo. id say go for it. it should make good power with little mods
Old Aug 12, 2010 | 07:26 PM
Fastcount03's Avatar
Default Go for it!
If i had the money I would be tearing my truck apart right now to put it in! lol
Old Aug 12, 2010 | 10:56 PM
LS1MonteSS's Avatar
Thanks for the replies... I was just a little worried with it being so new that there haven't been any mods or post on them and as I mentioned I have no info on them in my books.. I did see a info post somewhere on all the particulars as Nightmare posted for me..
I do understand that it is the best situation when you can get the "whole ball of wax" as I can with this.. If I can pull off the deal it will be going into a 1970 Monte Carlo.. With that car tipping the scale at 4K pounds I knew I would need a strong motor to keep it fun.. The 350 (2B carb and original 56K miles) is still really strong but it needs a complete seal job from sitting around for so long..
Again thanks guys for the thumbs up, and if you come across any specific upgrades let me know.
Old Aug 12, 2010 | 10:57 PM
LS1MonteSS's Avatar
yeah if i had the money too! LOL It will be going on the plastic if the guy still wants to deal.
Old Sep 17, 2010 | 08:32 PM
LS1MonteSS's Avatar
Well it has been a while so I thought I'd fill you all in..
I picked up the L96.. it has L92 heads on it.. It only had "2" miles on the motor.. so this thing is newer that something you'd get from a dealers lot..
The 6L90E is one HUGE trany.. Speaking of which I will end up modifying the trany tunnel in my car to get her to fit in there.
Old Sep 17, 2010 | 08:37 PM
Hunt&Fisherator
Any ideas on how to run the electronics and control the trans? I'm sure you could modify a wiring harness from a newer vehicle to make work.
