L96 or Bust!!
The new transmissions are really "smart" they read the throttle position, engine speed, timing.. and a few other items and then determine if it is doing what it needs to be doing or if it needs to make a change.
To answer your question.. I did alot of asking and reading and the best way to do a swap to the new platforms is to get as much as you can from the donor vehicle. To start with because I got a complete package everything will work together. I basically just need to install it into the car and turn the key..
I could mod the existing 40 year old original wiring to tie into the the new stuff.. that is a ton of work and then I have the added worry of how long the old stuff will last.. So I do plan to mod a wiring harness from like a new camaro, gto, cts, or the van i got the motor from..
Once it is all in I still have to look into the trany.. being it came from a van the TUTD is not activated, the tire sizes will be different for the correct speedo reading.. then there are the enhancements that could be done to shift points and firmness of shifts..
The one thing I still have a question on is the converter.. I'm not sure the stock one will give me the performance I'm looking for.. I'm not going to race it but I want a sporty ride..
I couldn't pass it up.. I was going to piece it together, but once I looked at the cost of buying the items separately (motor, ecm and wiring, trany..) it made the best money sense to get the package.. and I know it will all work together as it did in the donor vehicle.
Timing wasn't the greatest for sure.. but the best deal for the money.
Circle-D is making 6L90E converters these days if I'm not mistaken. Yank may as well. Either one of those two companies can get you setup with something reliable as stock and WAY more fun to drive.
I haven't really thought about a cam or anything and I know that will be something they will want to know.
Still looking for a MAF part number for that.. Maybe I should check Rock Auto.. None of the local parts stores have anything listed..
Silver8ado
13
Oct 21, 2024 09:09 AM
but they are both of the GEN IV variety. What's the casting number on them?
