l92 to a 429 power??
Old Apr 4, 2010 | 02:17 AM
abcdefg's Avatar
and its a truck intake
Old Apr 4, 2010 | 08:25 AM
OnyxSilveradoSS's Avatar
500hp.
I have not seen super numbers w/o FI...I have never seen results where the extra CI was in the end any better than a 6.0L with some FI on top.
Old Apr 4, 2010 | 09:08 AM
dirt track racer 81's Avatar
The Vic Jr will allow you to turn more rpm which will make you more power. If you have a cable throttle body get a 4 barrel throttle body and not the elbow and tb. That motor will want some air, you can get a bigger 4 barrel throttle body than can a regular one.
Old Apr 4, 2010 | 09:59 AM
silver-mod-o's Avatar
Hunt&Fisherator
No way in hell I'd run any stock manifold on something like that, ported or not...
FAST 102 or Victor Jr intake with 4bbl TB, and for that many cubes, go with the 4500, not the 4150.
Old Apr 4, 2010 | 06:25 PM
abcdefg's Avatar
i hope its over 500 im hopin near 600 i think the 429 should get 500 on its own and it should be near 6 with ported heads cam and boltons
Old Apr 4, 2010 | 06:30 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The bottom of that block is going to have to be swiss cheesed to clear the rod bolts with that long *** stroke. Im NOT a fan of that long of a stroke on a daily driver. Even with the longer sleeves of an aluminum block youre eating that advantage up with the 4.125 over the normal 4". Stick with the stock bore and a 4" stroke that will be more reliable, better stability and last longer. The extra cubes is not worth it IMO.
Old Apr 4, 2010 | 06:32 PM
abcdefg's Avatar
so a better intake manifold will wake it up guess im going to have to look into that.. i asked a few mechanics nd was told a intake manifold wasnt necessary for my setup unless i wanted a big shot of nitrous or f/i
Old Apr 4, 2010 | 06:38 PM
abcdefg's Avatar
not really a daily more like a weekend cruiser but yea i was planning on goin with that to make the 418 but the shop i went too had just built a 429 and said it was running real strong with no problems and i was pretty much convinced to do the 429 its already built and it feels good was just wondering around how much power i was pushing
Old Apr 4, 2010 | 06:56 PM
1slow01Z71's Avatar
I merged your threads together, please only one thread per topic.
Im sure your truck is making good power, throw it on a dyno. I agree with silvermodo about the intake.
What is the rest of your setup?
Old Apr 4, 2010 | 07:38 PM
abcdefg's Avatar
thanks i wasnt sure where to put it.. and i am going to dyno it on the 17th was just curious to what i should expect to see..
and setup besides the engine a 3500-3600 precision ind stall to a built 4l65e and 3.42s but most likely going to change the gears since its no longer a daily.. and mostlikly will be goin with a 100-200 shot see how long the tranny last lol
