L86 rough idle
Old Jul 25, 2018 | 09:30 AM
whyt00's Avatar
Default L86 rough idle
Since moving to Idaho I’ve lost access to a lot of friends with nice diagnostic equipment so I’m having to rely on what the guy at the parts store with the cheap scanner tells me. Earlier this year I bought a 2014 Sierra with the 6.2, it’s great I love it and I’ve already racked up some miles to where the truck now has 124,000 on the odometer. About a week ago I noticed it would hiccup at idle, I didn’t think too much of it until my wife even noticed it and later that day the CEL came on. So I went by a parts store and had them throw a scanner on it and the guy said it was a cylinder 8 misfire. Okay no problem I’ll just grab a new set of plugs and that will be that, not so much. It does seem less noticeable but it is still there none the less. After doing some google searches I decided to ohm out a couple plug wires and they were all pretty close about 3,800 ohms (crazy for such a short wire). Next thing I found on google was potentially a large amount of carbon buildup on the valves because of the direct injection, so I pulled the intake and there was barely any. While it was apart I checked the intake gaskets, and I cleaned the throttle body and MAF and put back together. Again it felt a little better but I can still feel it at idle in gear. My next logical step would be compression test and maybe a coil (is there a way to test the coils?). I’ve read some more serious problems are out there, I’m just looking for some input as to where to go next and any helpful insights.
Old Jul 26, 2018 | 10:04 AM
Vortec350ss's Avatar
it could be the injectors. Without scan tools its tough to see what is going on obviously. I am curious if the fuel trims are showing anything funky. I think DI are prone to clogging injectors more than an injector in the intake runner would be.
Does fuel injector cleaner work? It may be worth a shot. I'm not saying this because its a known issue I have seen, just thinking out loud and trying to help.
Old Jul 27, 2018 | 08:34 AM
Mark Johnson's Avatar
A couple bottles of gummout thru the gas tank...……….
Old Aug 17, 2018 | 05:45 PM
whyt00's Avatar
I still haven’t been able to fix this yet, so far I’ve replaced all of the spark plugs and that didn’t fix it. The cylinder 8 misfire code came back almost immediately, then I swapped the coil and plug wire for #8 to #1 and it took a couple days for the light to come back on, but it was still cylinder 8 misfire. I checked compression on a few cylinders all that I tested were around 210psi. Spoke with a tech at the GM garage and they suggested replacing the PCV valve, it was only a few dollars so I did and it still wasn’t fixed so then I tried a couple bottles of fuel injector cleaner (I’ve always been skeptical of this stuff but was willing to try it) and it still does it. I know I could just take it to a shop, but I have a baby on the way and can’t afford to spend money on the truck right now. Again any input is greatly appreciated.
Old Aug 17, 2018 | 07:38 PM
Littlefield's Avatar
Pull the valve cover a see if there is a loose rocker. Could be a stuck lifter.
Old Aug 18, 2018 | 08:40 AM
swathdiver's Avatar
5 Year Member
Quit guessing and get the right tools for the job. You need GMs MDI with GDS2 software. It's the modern equivalent for your truck as a Tech2 is to mine. Same tool GM techs use at the dealership.
Old Aug 18, 2018 | 09:17 AM
Re my earlier post, #8 is not an AFM cylinder and shouldn’t have the problems associated with lifter collapse. My bad.
Old Aug 18, 2018 | 10:10 AM
swathdiver's Avatar
5 Year Member
Non AFM lifters still go bad, so don't rule it out yet.
Old May 6, 2019 | 12:53 PM
Sssnake's Avatar
Any resolution to this? I am experiencing the same thing with my 15 L86.
Old May 28, 2019 | 05:43 PM
00pooterSS's Avatar
Probably a bad injector if you have good spark and good compression.
That would be my next step.
rjw
Aug 7, 2016 01:19 PM
jrs01
13
Feb 3, 2015 12:19 AM
01WS6/tamu
Jul 5, 2013 11:48 PM
WhiteX
Feb 13, 2013 09:46 PM
trxmxzx
May 19, 2007 07:21 PM
