L76 fuel rails w/truck injectors???
5 year bitches!
question is why? youll make more power then the truck 30s will ever handle. now if you had SV0 30s its a different ball game. if yoru taking hte time to do teh car intake swap just swap over to car injectors
and you need a return style fuel rail and the l76 rail isnt returnstyle. you can mod a 97-98 vette one to work for the L76 intake. thats what i used for my last combo
10 Second Truck Club
You can use your existing injectors, they just won't be big enough probably. Then later change them out to 44lb. marine injectors. All you have to do is drill the intake out at the injector holes with a 1/2" drill bit(but no bigger) get the bigger o-rings and place 4 .280" thick spacers under than fuel rail brackets. This way you don't have to change the wiring harness. This how I just did my LS7 and it's the same for the L92.
GMCtrk
07-17-2015 06:39 PM
