L33 500hp build
Old May 29, 2016 | 08:33 PM
BlueTexan24's Avatar
500 crank hp is doable, idk why sometimes people act like that's so hard. With a badass set of heads like some trickflows with a small chamber to get the compression up and a mid to upper 220 duration cam. Google the 5.3 l33 they built over on pro touring that made 499hp at the crank with trickflow heads and their 220/224 cam and a shitty ls2 intake.
Old May 29, 2016 | 10:37 PM
wenzl90's Avatar
Well im trying to stay away from forced induction. But who knows i might change my mind down the road. Actually i planned on swappin to 4.10s in the rear. I plan on puttin the RC leveling kit and 33s on it. Had good experience with that kit before. I know 500chp is doable but the only thing that converns me is drivability. With adding a stall thats where im ignorant at. I know a lot of people use them but dint u derstand exactly what it does. This truck will be a dd mild offroader work type truck. Dont really do much towing. I just want a good street truck with some pep and 500hp is a goal but if i gotta dial those numbers down so be it.
Off topic but has anybody had any experience with the truck flow products or speed engineering products?
Old May 29, 2016 | 11:27 PM
Cowboy Tom's Avatar
If you going with 33x12.50 then might want to consider 4.30's,
I'm kinda where ur at, still planning my build I got an 2008 Silverado 5.3, I'd like 400-500HP (crank)
I'm debating 4.10 or 4.30's I also plan on doing a 2" level with 285's (32.7") I beifly considered 4.56's
so far the truck is just exhaust, mail order tune, corvette servo and Circle D 2800 stall converter, I absolutely love the stall converter, Its just a 2800 so not too high, truck still drives near stock when I'm not on the gas, but mash it and I can get Mustang's off the line now, also spins tires so much more now
Old May 29, 2016 | 11:40 PM
Cowboy Tom's Avatar
My plans are CAI, performance TB, port polish heads, mild cam, long tube headers, custom tune, and 75 or 100shot nitrous , and already got stall converter.
I've thought about decking heads slighty to bump compression but idk if i wanna increase compression if I ever run nitrous. I'd hope to make about 450hp on motor and little over 500hp on NX
Old May 30, 2016 | 12:03 AM
wenzl90's Avatar
See thats another thing im not sure i want to do about heads. Buy a new set or just get the current ones ported. There was a top end kit from trick flow that claims to hit 455hp but i know how advertised numbers go. I know just basic mods can really wake the 5.3 up. My 03 was pretty peppy after exhaust cai and headers. Didnt have a tune. Tried hypertech but that thing sucked. Also mine had 3.73 gears. I just want to do this build the right way first time around. Im in the army so i dont make a lot haha
Old May 30, 2016 | 04:48 AM
10 Second Club
The link previously posted wasn't working, just fixed it - check it out. 484 at the crank, looks easy to duplicate. I would skip the FAST intake substitute a TBSS intake. Spend that money elsewhere.
Old Jun 5, 2016 | 05:53 AM
wenzl90's Avatar
Thanks for the input guys. Got some good info. But just curious i think i asked before has anyone had experience with speed engineering products? Also if im able to get this much horsepower what size headers should i use 1 3/4 or 1 7/8?
Old Jun 5, 2016 | 07:22 PM
10 Second Club
1.75" should suffice, 1.875" might produce slightly more peak. But, will shift the power curve higher in the band. Sacrificing some low end.
I am about to install a set of Speed Engineering headers on my truck this week. They look nice for the price, hoping the fit is good.
Old Jun 10, 2016 | 10:31 PM
wenzl90's Avatar
Let me know what you think about them ive been really curious
Old Jun 11, 2016 | 02:33 PM
10 Second Club
I put them on this morning, they went in fairly easy. I replaced my engine mounts with brand new GM mounts. I have good clearance everywhere.
01SilveradoJakee
11
May 30, 2016 09:17 AM
About20ninj45
Apr 27, 2016 06:32 PM
Shtbox
Mar 7, 2016 04:31 PM
05RST2NV
Mar 6, 2016 10:45 PM
Northeastconfederate
Mar 4, 2016 01:50 PM
