L31 magnaflows
OK I need some help deciding what to do with my exhaust. I AM getting magnaflows. That much I know, but I could either do a single outlet behind the right rear tire (like stock) catback. Or I could do true dual magna's 2 pipes in front of right rear tire. Which would be louder? and Which would see better gains? I have heard that true duals kill low end power but I don't really know. Thanks!
honestly the dual exit before the right wheel would be better because there is less restriction unless you let it drop before or directly after the rear axle. the more bends and longer tubin, restrict more air. or do like i did and just dump it under the cab, cats go and the stock muffler stays the only bad thing is no back pressure so i get hardly any help off the line.
