Kr problems??
Old May 12, 2005 | 09:27 PM
slowride_3's Avatar
Default Kr problems??
What are the symptoms of kr?
Old May 13, 2005 | 01:54 AM
slowride_3's Avatar
Default Knock Retard
Come on I know someone can tell me.
Old May 13, 2005 | 11:27 AM
budhayes3's Avatar
PT's Slowest Truck
KR...the PCM pulls timing because it's getting a signal from the knock sensor, and you don't have power under load. It can pull timing even under small load conditions, but it's most noticeable when you get on it. If the vehicle is actually pinging, you might hear it. Best way to check if you're getting KR is with a scan tool.
Old May 13, 2005 | 12:43 PM
KySilverado's Avatar
Doubt you would feel or detect KR without a scan tool. Unless something is really wrong. Knock Retard is PCM retarding timing when it senses Knock via the Knock sensors. Designed to sense detonation/ping and protect the engine from damage. Other things can trip it also. Noisy valvetrain, exhaust banging the frame and such.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
