Hard to start after Radix Install
Old May 11, 2005 | 01:44 PM
Breeze's Avatar
11 Second Truck Club
Default Hard to start after Radix Install
Ever since the Radix install the Truck is hard to start I find myself having to crank the key longer then ever. Does anyone know what problem could be?
Old May 11, 2005 | 02:02 PM
onyx's Avatar
14 Second Truck Club
is the FPR installed correctly?
Old May 11, 2005 | 02:16 PM
Breeze's Avatar
What is the FPR? Ill check it as far as I know everything is installed correctly.
Old May 11, 2005 | 02:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
Fuel Pressure Regulator, it is on the driverside fuel rail, remove it and reinstall it. I know you all have heard how important the lube is on this. Take it out, inspect the o-ring......make sure it is not damaged!! Re-install it will a LIBERAL amount of lube, Vasaline works the best
99.9% of the time this is the problem.
Old May 11, 2005 | 03:01 PM
BigTex's Avatar
Also make sure the little rubber O-rings are properly in place. I had one get pinched and it caused a similar effect like you have.
Old May 11, 2005 | 03:54 PM
Breeze's Avatar
You guys are the Best. This thing is runnin perfectly if I could just get some Traction.
Old May 11, 2005 | 04:02 PM
BlownChevy's Avatar
blownerator
25 Year Member
HAHHAAHA good luck! Glad you got it fixed.
Old May 11, 2005 | 04:04 PM
BigTex's Avatar
Find an open parking lot, come to a complete stop. Put the shifter in 3rd gear. Press in the tow-haul button. Slowly take off and at 15mph, give it full throttle.
That doesn't help with traction, but it does put a big grin on your face.
Old May 11, 2005 | 04:06 PM
BlownChevy's Avatar
blownerator
25 Year Member
Old May 11, 2005 | 04:26 PM
Breeze's Avatar
Oh its allready put lots of on my face
