knock sensors! someone help please!
Old Aug 11, 2010 | 08:18 PM
dlt76028's Avatar
Just thought about it, they DO screw into the block and the valley cover should have some black rubber seals that prevent oil from coming up.
Old Aug 11, 2010 | 08:21 PM
dlt76028's Avatar
You can see where they screw into the block.
Old Aug 11, 2010 | 08:25 PM
1LOW4X4's Avatar
Banned
They screw into the block, ur fucked! After I did mine the other day (used oem) the Code stayed on for a sec but hasn't come back on since.
If it's stripped Out in the block and holding the valley cover on, idk what the he'll to do
Old Aug 11, 2010 | 08:28 PM
1LOW4X4's Avatar
Banned
Try undoing the valley cover bolts and prying up on it. Maybe it'll work if the sensor is broke off in there. The valley cover gasket is reuseable unless you mess it up
Old Aug 11, 2010 | 08:35 PM
bighoss77's Avatar
no the sensor is out! just the threaded part of the sensor broke off flush into the threaded hole. so ill be able to get the cover off, just have to find a way to get the part that broke off out of the threads... wonder if some easy outs will work? got a brand new set i havent used yet... but also, why the hell is there a hole in the valley cover? let me go see if i can snap a pic right quick!
Old Aug 11, 2010 | 08:40 PM
1LOW4X4's Avatar
Banned
The only way I can see a hole being in the valley cover is if the rubber grommet that holds oil in and that the sensor sits in, is fucked up. Which is very possible
Old Aug 11, 2010 | 08:42 PM
GMCtrk's Avatar
drill it out!
Old Aug 11, 2010 | 08:43 PM
bighoss77's Avatar
can you see the hole??? the hole is on the backside of the "hole", kinda off to the left a little bit. wtf is it for? you can see all the oil in the bottom from the hole
and here is where the sensor broke off!
Old Aug 11, 2010 | 08:48 PM
dlt76028's Avatar
looks like a hole in the valley cover letting oil in. get a new valley cover.
Old Aug 11, 2010 | 08:50 PM
1LOW4X4's Avatar
Banned
Under the sensor there is a stiff rubber grommet that the sensor sits in, it is built onthe valley cover, although they can be replaced if need be. Pull the valley cover off and inspect the grommet. There should be only one hole, the hole that the sensors goes thru to screw in the block
Edit: is the hole in metal or rubber? I cant tell
