just weighed the truck
Old Aug 15, 2002 | 08:50 PM
GMC SKI's Avatar
Default just weighed the truck
well I got a chance to weigh the truck
result with me and all my goodies
4540lbs with a 1/4 tank of fuel
without my fat *** and with my A.R.E. hard tonneau were looking at a final weight of :
4200lbs or so ..
Now how much do lightnings wiegh ?
now if i can safly shave off a few pounds were cooking <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 15, 2002 | 09:13 PM
CHAGO's Avatar
Default Re: just weighed the truck
LIGHTNING INFO:
Powertrain
TECHNICAL DATA ENGINE
Configuration Longitudinally mounted, single overhead cam, 90-degree Triton™ V-8 supercharged/intercooled, cast iron block, aluminum-alloy heads, forged steel crankshaft
Bore x Stroke 90mm x 105.6mm
Displacement 5,410cc (330cid)
Compression ratio 8.4:1
Horsepower 380 hp @ 4,750 rpm
Torque 450 lb.-ft. @ 3,250 rpm
Specific output 70.2 horsepower per liter
Redline 5,250 rpm (fuel shut-off @ 5,400 rpm)
Valvetrain Single overhead camshafts, chain drive, roller finger followers with hydraulic lash adjustment, beehive valve springs, two valves per cylinder
Intake valves 1 per cylinder, 44.5mm head diameter
Exhaust valves 1 per cylinder, 36mm head diameter
Fuel system Sequential electronic fuel injection, premium calibration
Induction system Pressure-charged with Eaton™ Corporation Generation IV Roots-type supercharger; water-to-air intercooler
Supercharger 8.0 psi pressure
Throttle body Dual-bore 57mm
Mass-air sensor 90mm diameter
Exhaust manifolds Cast-iron tuned header-style manifold
Exhaust system Tuned dual exhaust, ceramic-coated dual exhaust tips
DRIVETRAIN
Transmission Four-speed automatic (4R100)
Drive Shaft 4.5-in. aluminum
Rear axle 9.75-in. ring gear with limited-slip differential, 3.73:1 ratio
Gear Ratio Maximum Speed In Gear
1st 2.71 43 mph (68 km/h)
2nd 1.53 76 mph (123 km/h)
3rd 1.00 119 mph (191 km/h)
4th 0.71 142 mph (228 km/h)
Reverse 2.176
SUSPENSION
Front Short- and long-arm type, coil springs, tubular gas-charged Bilstein shock absorbers, 31mm solid stabilizer bar
Rear Solid axle, staggered gas-charged Bilstein shock absorbers, five-leaf springs, 23mm solid stabilizer bar
STEERING
Type Recirculating ball, power assist
Gear ratio 14.0:1
Turns, lock to lock 3.3
Turning diameter 44.3 ft.
BRAKES
Front 12.1 in. (308mm) vented disc, twin-piston caliper
Rear 13.1 in. (334mm) vented disc, single-piston caliper
ABS Four-wheel, three-sensor system
WHEELS & TIRES
Wheels 18 x 9.5 in., five spoke, cast-aluminum alloy, painted surface
Tires Goodyear™ Eagle F1-GS™, 295/45ZR-18, unidirectional tread; 235/70R-16 spare tire
DIMENSIONS AND CAPACITIES
Wheelbase 119.8 in. (3,043mm)
Length 208 in. (5,283mm)
Height 70.9 in. (1,801mm)
Width 79.1 in. (2,009mm)
Track, f/r 65.3 in. / 65.3 in. (1,661mm / 1,661mm)
Head room 40.8 in. (1,036mm)
Leg room 40.9 in. (1,039mm)
Shoulder room 63.8 in. (1,621mm)
Hip room 61.0 in. (1,549mm)
Curb weight 4,670 lb. (2,120 kg)
Fuel capacity 25 gallons (94.62 liters)
Weight distribution, f/r 57% / 43%
Payload
800 lb. (363kg)
Towing capacity 5,000 lb. (2,270kg)
PERFORMANCE
0-60 mph 5.8 seconds
Quarter mile 13.9 seconds @ 100 mph
0-100 km/h 5.9 seconds
0-100-0 mph 22.0 seconds
Top speed 142 mph (228 km/h)
Braking, 60-0 mph 136 ft.
Braking, 80-0 mph 238 ft.
80 ft. slalom 63.6 mph
100 ft. skidpad 0.85g
Fuel economy (estimated) 13 mpg city
Old Aug 15, 2002 | 10:09 PM
XLR8NSS's Avatar
Adkoonerstrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GMC SKI:
<strong>well I got a chance to weigh the truck
4200lbs or so ..
now if i can safly shave off a few pounds were cooking <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Man, that sounds pretty good. I can see a raceweight for my truck of close to 4000lbs with my lightweight *** driving <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> and a little weight reduction. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John
Old Aug 15, 2002 | 10:43 PM
really slow truck's Avatar
man, i wish i had a SC but i sure do love that trash can in the back <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> i just wanna get down into the 45XX range with my EC truck. we will see how THAT goes lol
any body wanna get in on a group purchase of slim fast??? <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> im not fat but i sure do have a nice size beer belly <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
good luck with the weight reduction gmc ski and john
bryan
Old Aug 16, 2002 | 08:29 AM
BigTex's Avatar
What is raceweight? I have always thought that my toolbox full of crap made me get better traction <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Back in my day, we ... well ... anyway...
Nothing is going to get me under 5000 lbs. hehehe.
Old Aug 16, 2002 | 08:42 AM
RED2K's Avatar
Do they sell it in 55 gallon drums of it? maybe we could get them tobe a sponser. <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
Old Aug 26, 2002 | 03:56 PM
XLR8NSS's Avatar
Adkoonerstrator
Hey, went to a truck scale after work today and weighed the truck.
It came in at 4340#'s. That is with me in the truck and about 10gals of gas.
The only thing that isn't stock on the truck that would reduce the weight is the JBA headers but, it has true dual exhaust with two flowmaster mufflers that add a little weight back.
Without my 140# carcass the truck would weigh right at 4200#'s, right on GMC SKI's numbers. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Kinda makes you wonder if the fleetsides are lighter, like some people are saying, or not. I don't think so. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
John
<small>[ August 26, 2002, 04:52 PM: Message edited by: XLR8NSS ]</small>
Old Aug 29, 2002 | 08:25 PM
BigKID's Avatar
Dang... I need to put my truck on a diet. Mine weighed in at 4400 even without me in it. 1/4 tank gas, no spare. I think my stereo equipment, 18's and Hotchkis springs are what is bringing my weight up. BTW... I weigh in at 220 so that dosnt help a whole lot on race day either. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 29, 2002 | 09:50 PM
SPRAYEDSIERRA's Avatar
11 Second Club
Hey BigKid, why dont you spray that heavy thing and it'll run faster <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> When we gonna run again? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 29, 2002 | 10:24 PM
OVER TORQUED's Avatar
Damm?! I must have a tank 6500lbs without me. That before I added my tool.
<small>[ August 29, 2002, 10:26 PM: Message edited by: OVER TORQUED ]</small>
