Just Ordered A 6.0
FormerVendor
Its a 2005 6.0 that came out of a Chevy Express van.
Heres the question...
The 2005 came with ETC (electronic throttle control) or DBW (drive by wire)
i do not want this so the place i bought the 6.0 from is putting on an older 6.0 intake mainifold that was cable driven on the motor. This will take care of that issue correct?
Also the seller said sometimes the PCM's are locked he wasnt sure if mine was.
I am getting a tune, can a tuner unlock a locked PCM or should i just get a nelson tune and get a new PCM?
Thanks
Thanks
The intake swap is all that is needed to run a cable-throttle...you've got that covered
Most tuners can unlock a PCM, if it's a stock PCM it'll be unlocked already. On another note though....a 2005 PCM won't work in anything below '05, you'll probably have to use your stock PCM with the 6.0 and have it programmed
FormerVendor
The engine is coming complete.
Can i just unplug the 05 PCM and plug in mine?
The reason im asking is because i do not want to remove the wiring harness off of the 05 engine since it is coming already attached..
Also I think the vans come with an 4l80e. Will this motor bolt up to the 65e?
Thanks.
Thanks.
Thanks.
Thanks.
Originally Posted by thunder550
It is MUCH easier to remove the harness off a new motor than it is to remove the one from the truck. Just keep the one in the truck. Swap motor for motor, don't change the electronics. You will need a new flexplate for the tranny....I have a stock one from a 4L65E that I need to get rid of, BTW....if you're interested PM me.
FormerVendor
Originally Posted by Okie5.3
did a swap in a buddies truck that had a cable TB. all ya need is the drivers side rail for the FPR, crossover tube, and like BADMOFO said, the threaded inserts for the brackets.
