Joe gibbs LS30 oil
Has anybody used this stuff? Is it any good?
I have a bolt ons/tune 4.8 with 100k on the clock, would it do any good? Seeing as how it's made for the LS/LT engines..I've been running mobil 1 high performance, and before valvoline max life since I work for them, but it sucks (don't recommend it) and use a factory ac delco filter
Any advice is appreciated! Thanks!
First time I've heard of it, but I'd look at the cost first. Oil is oil really, if mobil 1 has been working for you fine just keep running it.
I would upgrade your filter though, AC Delco's are cheap *** china filters and are pure junk. Switch to a wix filter.
Idk just wanted to check it out since it's supposedly engineered with more zinc and whatnot, and made for LS engines
And I haven't had any problem with ac delco, been running them since I got the truck 2 years ago, and see them on trucks at work all the time, I tried using fram and it dropped my oil pressure so I went back to the Ac delco
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
