Was it Jody that's getting a knockout box?
Well Gonzo, Tony is a busy guy. He just got all the needed parts and he is going to assemble it tommorow and ship it out on Thursday. I will let everyone know how well it works after I make a few runs with it. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> I hope it works pretty good because I am giving up a lot of timing on the WOT blasts. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
That sucks that it takes him that long to get the parts. If your stuff works, I bet he gets quite a few more orders from guys here on the truck section. We may need a GP. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Hey JW
Did you get one with the harness?It sounds like it gets a little involved to install it if you buy one without the harness.You have to remove the intake? and you have to open the connector at the PCM and remove and replace one of the pins?Let me know if i am all wet here.
Yup, sprung for the one with the harness. As far as I know it just slips in between the connector under the intake "cover". I have the 2001 rounded cover on my intake so only one 8 mm bolt and she is off. That is why I got the one with the harness so I can unplug it if I need to for very long trips to the beach. On that I would rather be safe and have kr then sorry.
On the one without the harness you can just splice in under the cover also but is more of a permanent install. Its easier I imagine to do it at the pcm on the f-bods.
Gonzo as you know two wires off the ks go into the pcm, one wire for each. The ko box has two wrires in and two out. Simple splice in procedure.
