it's alive!! now how do i tune for a BIG cam?
Old Feb 14, 2004 | 04:21 AM
parish8's Avatar
single digit dreamer
Default it's alive!! now how do i tune for a BIG cam?
time to do some research, got to learn how to tune for this cam.
truck fired right up and idled for a few seconds, then got real lumpy and died. i uped all the idles with edit by 300rpm's so the min is now about 900rpm, still wont idle. i can hold it up around 1100rpm and it will idle ok but gets kinda wierd when i shift it in and out of gear. i knew it would need some "tuning" just dont know what that means exactly, anyone have any sugestions?
it it sooooo nice to hear it run again, now i get to play with the laptop and not wrenches for awhile.
Old Feb 14, 2004 | 04:35 AM
L-EATER's Avatar
11 Second Truck Club
I wanna know too. I should have mine running this week, and I will need tuning also. I asked this over in the pcm section and didn't really get an answer. I have read that you need to scale the 1st 3 rows of the VE table by about 80% to make it idle. I guess that makes sense 'cause the bigger cam is gonna have less idle vacuum and you have to lean it down some way or it will be way too rich. Might try that and see.
Old Feb 14, 2004 | 04:42 AM
parish8's Avatar
here is a great thread, you may need to register http://www.ls1tuning.com/iboard/index.php?showtopic=9
i hope to try that stuff tomorrow, sounds prety easy. afraid it is time for bed right now, might even have to wait till sunday to try that stuff cause i need to spend a little time with the woman tomorrow.
Old Feb 14, 2004 | 05:08 AM
Banned
i need a damn scanner, i have a great little "booklet" that has a bunch of cam tuning basics as well as the more intricate stuff....i'll see if i can find it online somewhere.
Old Feb 14, 2004 | 07:59 AM
BigTex's Avatar
Cool. We need spme sound clips of a loping and choking monster.
From your other cam post:
Originally Posted by BigTex
It should run, but a tune will be mandatory. You are about to learn a completely different side to the Edit tuning: idle and drivability.
Old Feb 14, 2004 | 08:02 AM
BigTex's Avatar
Raise your timing a few degrees in the 1200 and under rpms in both tables. Obviously raise your idle timing. You'll also need to modify your main VE table in the lower rpms to asjust fueling. Depending on how it acts with quick jabs to your throttle, you may need to adjust your Idle Air table.
Old Feb 14, 2004 | 09:27 AM
parish8's Avatar
your going to get a BIG head being right all the time
Old Feb 14, 2004 | 09:52 AM
big cam tuning... thats a good thread parish8. you beat me to it.
BigTex, can you elaborate a little on this:
Old Feb 14, 2004 | 10:56 AM
Flyer's Avatar
Yea .. which way does the idle air tuning need to go ... another question ...
WTF do we do if the TB doesn't have a hole in it to start with to enlarge. What should we adjust in EDIT to make it think it 'has a bigger hole' in the TB blade?
Old Feb 14, 2004 | 11:55 AM
GMC SKI's Avatar
At What point do you start to make holes in the throttle body blade ?
I have a few in mine Just don't know when to do that
