Its Is Alive!!!!!!!!!!!!!!!!!!!!
Old Jun 22, 2007 | 08:52 PM
2004SSS's Avatar
Default Its Is Alive!!!!!!!!!!!!!!!!!!!!
Had a great day. Got my ported and super polished tb in today so it was all go. bolted it on , then tested fuel pressure to find a few leaks and low pressure. pulled a rail to fix a leak and re teflon some fittings. all was good but still low pressure. DUH the fpr was set at 35 psi , crank it down a bit to reach 58 psi with no leaks. then proceeded to check for oil pressure( pulled fuel pump relay and pulled off blower feed line) cranked it over a few times to find oil pressure was good. so the scary moment came. plugged everything in and fired her up , she came to life as fast as a stock truck. oil pressure was about 65-70 psi on start up then came down to 60 psi at idle( thanks lpe oil pump) . she idles like stock almost , the coolest part is not one code was set during the few mintues it was run. when it was close loop it idles fine but when it went into open loop it started to jump around and then finally died so i need some fine tuning to get it running ok for break in. i was very excited to say the least. the coolest part was i didnt even expect to start it today but just got the bug to finish it.
VIDEO COMING IN A MINTUE
hopefully get a decent tune to get me put around tommorrow . shouldnt be long now.
here are some pics i snapped durign the install of the pipes .
have to clean up some wires and the methanol line. but overall it came out pretty nice.
Old Jun 22, 2007 | 09:02 PM
Bill Reid's Avatar
God DAMN thats a nice lookin setup!!!
Bill
Old Jun 22, 2007 | 09:05 PM
Lord Aries's Avatar
Amen to the niceness!!!! kickazz!!!!
Old Jun 22, 2007 | 09:11 PM
2004SSS's Avatar
here is the vid, notice me getting a little excited, the reason its get a little loud is because i opend the cutouts.
Old Jun 22, 2007 | 09:12 PM
53bowtie's Avatar
this is what i am doing as i am looking at your pics. that is one heck of a nice setup man!!!!
Old Jun 22, 2007 | 09:25 PM
Dock Rocker's Avatar
Congats man..I have been watching this build for a while its nice to see it all come together.
Old Jun 22, 2007 | 09:31 PM
Holty's Avatar
Notorious BIG
very NICE Chase, looks awesome!
Old Jun 22, 2007 | 09:55 PM
03sierraslt's Avatar
Good deal man, Glad to see you got it fired up.
Old Jun 23, 2007 | 02:07 AM
2004SSS's Avatar
thansk fellas im very excitied , it took long enough but hopefully it will be worth it. i think the hard part is done though, at least most of the physical part. tommorrow i should be installing the rest of the electronics for the alky and hooking up the catch can. swapping the deuce deuce's back on.
Old Jun 23, 2007 | 03:30 AM
Spoolin's Avatar
GFYS and STFU
Congrats Chase! Glad it's finally running you'll be hitting the streets in no time!! Cheers!
