Intank, inline or boost a pump?
Old Mar 2, 2006 | 09:49 AM
02sierraz71_5.3's Avatar
Default Intank, inline or boost a pump?
Have a guy who is loosing 20psi pressure at WOT with 42lbers. I figure the intank pump is the best option but it costs the most, is the inline just as reliable?
Old Mar 2, 2006 | 09:59 AM
dewmanshu's Avatar
Moderately Differentiated
year? return or returnless? Not that I would knwo the answer but I figure those items would help.
Old Mar 2, 2006 | 10:45 AM
zippy's Avatar
this depends on his abilities. if dropping the tank is an option as well as making the pump conversion work, i recomend that. otherwise it simply depends on his fuel system. if you have a returnless system the boost a pump works well. if you have a return fuel system the inline pump works out well.
Old Mar 2, 2006 | 10:53 AM
Whippled 496's Avatar
https://www.performancetrucks.net/fo...d.php?t=359939
Old Mar 2, 2006 | 11:09 AM
Wilde Racing's Avatar
How do I change this text
If you go the in-tank route, I'd pull the bed, Much easier than dropping the tank!
Old Mar 2, 2006 | 11:20 AM
dropping the tank wasnt to bad as long as you have less than a 1/4 tank of gas in there. It was 4 quick disconnects, filler tube, evap canister, and 2 straps + ground wire. I had it on the floor inside of an hour by myself. Most of the time was wrestling with what to do with the pump i had to put in. As you read in that thread, i decided to keep it stock instead of losing some of the functionality of the stock bucket and its abilities. Floor jack and a piece of 1x6 make it a little easier to drop also. I have never done it by taking off the bed, so i cant say whether its easier that way or not but i would imagine it is, just definately not a one man job that way... .
Old Mar 2, 2006 | 11:47 AM
can an inline reliably make up 20psi wot?
Old Mar 2, 2006 | 12:24 PM
zippy's Avatar
it needs to make way more than 20psi.
what's an intake pump???
Old Mar 2, 2006 | 12:30 PM
I have done it both ways, dropping the tank (with less than 1/4 tank), and pulling the bed. It is much easier IMHO to pull the bed.
It is a one man job if you have rafters and a come-along.
There is some good info about in-tank pumps as well as inline pumps.
In-tank fuel pump thread
Old Mar 2, 2006 | 12:39 PM
dewmanshu's Avatar
LOL I believe he is saying the system now is losing 20psi at WOT. Will the inline make up the difference...get it back to where it needs to be?
I think he meant in-taNk pump.
