Intake options for DBW TB
Old Aug 14, 2007 | 06:27 AM
Silver-Dollar's Avatar
Default Intake options for DBW TB
Ok - I did use the search button. Are the LS2 TBSS and SSR intakes with the 90mm dbw the only direct replacement intake manifolds (other than vic jr) without running into interference with the water pump neck? I am trying to decide on future power adders.
Old Aug 14, 2007 | 06:30 PM
nightrunner's Avatar
Mr. Obvious
radix
but yes, the LS2-truck and vic jr./GMPP carb'd style are the only direct replacement intake manifolds that i know of for any truck
Old Aug 14, 2007 | 08:45 PM
Debating between
Radix
ATI Procharger/Vic Jr/Wilson Elbow/DBW 90mm from SSR-TBSS
SSR-TBSS intake/DBW 90mm/Nitrous
or just add nitrous.
Old Aug 15, 2007 | 05:51 AM
tdrumm's Avatar
While they require no waterpump or belt routing mods, they still aren't a direct replacement. You still need to do a little fabrication for your return style fuel system.
Thunder550 covered it pretty well in his thread.
Old Aug 15, 2007 | 05:54 AM
I have a returnless fuel system.
Old Aug 15, 2007 | 09:06 AM
SS_bnoon_SS's Avatar
Weird, my 2003 is return style...
Old Aug 15, 2007 | 09:34 AM
2005 lq9 from Escalade. I could be mistaken.
Old Aug 15, 2007 | 10:34 AM
tdrumm's Avatar
The returnless style didn't start until 2004, so your truck orginally came with a return style.
I'm assuming that you didn't install your LQ9 yet, or else you would have had to either swap over your old return style rail or swap in the entire fuel system from a returnless style truck for it to work.
Old Aug 15, 2007 | 03:46 PM
You are correct sirs - I do have a return style. The fuel rails were switch over.
Old Aug 15, 2007 | 04:16 PM
tdrumm's Avatar
Yea, then you'll have a little modification to your rails to do. Like I said, Thunder550 covered it very well.
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
creekrat
Aug 2, 2015 01:27 AM
Slammed96
Jul 27, 2015 07:22 AM
